| Professional STI Racer Car: 07 UGM STi Fav Mod: Aux cord & Nitrogen in tires Location: San Diego & Temecula Posts: 655
IWSTI Addict since: Apr 2007 Trader Rating: (0) | I searched, and have not seen a thread like this so here it goes, and sorry if i sound like a newbie but... I plan on running the new RB320 suspension on my MY07 STI in the near future, and I was curious what the rim dia./width/offset & tire size parameters are for a otherwise stock car (including fenders), in both the preferred road and track settings. I also plan to get the rear sway and some Group N tophats, but that is about it. This is my DD. Right now I think some RA-R wheels and 235/40ZR18 are in my fure but I am also leaning towards a set of ADVAN RGII's or RS's in 18x8.5-9 and would really like to know what tires and offests will work with these sizes. I was also curious if there were any "ideal" sizes recommended by prodrive. I did see somewhere that the RB320 runs a 225/45ZR18 somehwere but now I cannot find it. I will be forwarding this thread to RCE and maybe the can help out. Road setting (Rear anti-roll bar in 2nd hole, nearest the end of the bar) Values are read: minimum / preferred / maximum Front Camber -1°20’ / -1°15’ / -1°10’ Front Toe-in (Total) 0°02’ / 0°06’ / 0°10’ Front Caster / 3°00’ (Referential value) / Rear Camber -2°15’ / -1°30’ / -0°54’(Std Subaru tolerance) Rear Toe-in (Total) 0°02’ / 0°60’ / 0°10’ Thrust angle -0°01’ / 0°00’ / 0°01’ Track setting (Rear anti roll bar in 1st hole, nearest the mounting bush on the bar) Values are read: preferred Front Camber -1°30’(Maximum negative on adjustment) Front Toe-in (Total) 0°06’ Front Caster 3°00’ (Referential value) Rear Camber -1°30’(Standard Subaru) Rear Toe-in (Total) 0°06’ Thrust angle 0°00’ This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,344
IWSTI Addict since: Apr 2005 Trader Rating: (10) | I would do a 18x8 or an 18x8.5 wheel with either a 235/40 or a 245/40 tires. That won't rub, but you can't go much wider or taller. To be safe, and since your car is strictly a DD, go with the 235's. RA-R wheels with 235's would be nice. - Andrew |
| | #3 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | What about a RGII in a 18x8.5 +50 |
| | #4 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,449
IWSTI Addict since: Dec 2004 Trader Rating: (7) | |
| | #5 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | I wonder if 255/35 or 245/35 would fit with a little fender manipulation? |
| | #6 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | of course it will. just a matter of how much manipulation you're willing to do. RE01R in 255/35/18 on some 18x8.5 +50mm RGIIs would be perdy nice. |
| | #7 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | It is funny that you bring up the RE01R... How much manipulation are we talking? |
| | #8 | |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | Quote:
it seems to differ on everyones car. for example crewcheif has 18x8.5 +45mm wheels and 255 tires and doesn't rub on RCE yellows where NandanRP tested (and loved) Boondocksaint's 17x8.5 +51mm wheels with 255 tires and rubbed in the rear on pinks. Boony's tires are obviously wider than crewcheifs. so will it rub? it's hard to say, but if you're willing to do a little add rear camber (more negative), grinding, or slight beating with a hammer the RE01Rs should fit with a +50mm offset. | |
| | #9 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | I have been looking @ soom Enkei RC-T4 18x8.5 48+ w/ 235/40s. I like the flushness of this offset. What do you guys think about the chanceo fit rubbing are rub? I do not want to stray from the Prodrive recommended alignment setting. |
| | #10 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | that will fit no problem. |
| | #11 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | What offsets in a 18x8.5 + 235/40 would rubbing start to be an issue? |
| | #12 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | +40mm on the low side. +55mm on the high side. |
| | #13 |
Car: 2004 Audi S4 Avant Fav Mod: wheels & suspension Location: Normal, IL Posts: 748
IWSTI Addict since: Oct 2004 Trader Rating: (5) | Mods delete please... Last edited by SilverSurfer; 12-25-2007 at 07:20 AM. |
| | #14 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | it depends on your suspension and how much camber you're willing to run. |
| | #15 |
IWSTI Addict since: Oct 2004 Trader Rating: (5) | Mods delete.... This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by SilverSurfer; 12-25-2007 at 07:20 AM. |
