| View Poll Results: Replace tires? | |||
| All 4 of them, your transmission will thank you. | | 4 | 44.44% |
| just replace 2, (the damaged tire and the one on the other side). | | 3 | 33.33% |
| what a load of ... just get the damaged tire your car will be OK. | | 2 | 22.22% |
| Voters: 9. You may not vote on this poll | |||
| | Thread Tools |
| Junior STI Driver Car: Black 07 STi Fav Mod: Coilovers Location: Miami Posts: 162
IWSTI Addict since: Mar 2007 Trader Rating: (0) | So i got a flat tire yesterday and the shop told me that they cant repair it because the screw is on the shoulder of the tire and that i need to replace that tire. researching on other forums i came across the comment that i should replace all 4 tires because the transmission will not 'like' having 1 new tire ant the rest half a way worn. My car has 12k miles on it; do I really need to replace all 4 tires? should i replace 2 (the damaged one and the one from the other side)? am I ok replacing just the damaged tire? This is a DD and i do about 6 AutoX a year. Thanks in Advanced. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Silver Member | See if you can find a stock tire from someone that has about the same amount of wear on it and about the same amount of miles. They say you shouldn't different tires becuase it will mess up the AWD system or something cause one or two tires are turning more or less then the worn tires and all that. I have had to replace a couple of tires. lucky for me though it was right around the same mileage as my old stockers in the basement so I would just find one that was close in wear and have that mounted. Been fine for me eversince. |
| | #3 |
| approved this message.
Car: Boony's Motown STi Fav Mod: 8-track tape deck, AM Radio Location: D3TR01T Posts: 23,095
IWSTI Addict since: Jun 2006 Trader Rating: (6) | The issue is the rotating diameters need to be within a tolerance. I do not know off the top of my head what that tolerance is, but for simplicity's sake, I'd say replace all four and sell the three old-but-good ones to autocrossers to recoup some of the cost. That's the safe bet, I think. |
| | #4 |
| Platinum Member | In a perfect world where money didn't matter, I would replace all 4. But, I don't live in a perfect world and money sure as hell DOES matter... So I would replace at least the bad tire and the tire across from it. Your dif will thank you. |
| | #6 |
| The Next Petter Solberg Car: 06 Subaru WRX STi Fav Mod: Cobb Xaust! Location: Houston,tx Posts: 904
IWSTI Addict since: Mar 2006 Trader Rating: (4) | just get a new tire and get it shaved off till it is to the other tires level... thats what i did... |
| | #7 |
IWSTI Addict since: Mar 2007 Trader Rating: (0) | kk, i took the tire to antoher place this morning and they repaired the tire. im done with AutoX for the rest of the year so i will be replacing these tires around february. since it is the front right tire i will place that tire on the back of the car in case that an AutoX comes in january. this last place quouted me the tires in $200 each installed and balanced. This ad is not endorsed by this member. Please register or login to hide this ad. |
