Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Braking
Old 09-25-2008, 04:46 AM   #1
Car: Blue 08 STI
IWSTI Addict since: Sep 2008
Default 08 STI brake pads
Do you know if 07 STI front brake pads would fit on a 08 STI ? I need to change the front brake pads, don't want to use the OEM ones from the dealer and all other brands I find online don't say it would fit on a 08 (only 07)
Thanks
andea79 is offline   Reply With Quote
Old 09-25-2008, 06:49 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Re: 08 STI brake pads
Pads are the same from 04-08 STI.
Old 09-25-2008, 08:14 AM   #3
Car: blue 08 STi
IWSTI Addict since: Jun 2008
What about the rotors, are these the same as well? Would that mean any rotor/pad for 04-07 sti's will fit the 08's? I have heard conflicting information.
eritz35 is offline   Reply With Quote
Old 09-25-2008, 09:00 AM   #4
Car: 2008 STI
IWSTI Addict since: May 2008
Trader Rating: (12)
Send a message via AIM to FlyingPerformance
Fronts are the same, rears are different
FlyingPerformance is online now   Reply With Quote
Old 09-26-2008, 10:57 PM   #5
Car: Totalled 06 WRX TR
IWSTI Addict since: Jul 2008
04's won't fit cause of the 5x100 and hub size.
EtoS is offline   Reply With Quote
Old 11-03-2008, 09:50 AM   #6
Car: Pure white MY08 STI
IWSTI Addict since: Oct 2007
The size is the same but the OEM's have different ordernumbers.
So the material is maybe little different however should not be a problem fitting when you go upgraded
suby555 is offline   Reply With Quote
Old 11-06-2008, 07:13 PM   #7
Trader Rating: (53)
The material is definitely different....it's worse than the old compound. I hate the new compound. No bite or feel at all.
Old 11-15-2008, 08:30 AM   #8
Car: 2008 WRB STI
IWSTI Addict since: Aug 2008
Is your STi still under warranty? Your bumper to bumper warranty covers new brake pads you know (but not rotors I believe). They may not be the greatest, but they are free (parts/labor).
JoeYu is offline   Reply With Quote
Old 11-15-2008, 10:52 AM   #9
Car: '05 CGM STi
IWSTI Addict since: Nov 2004
Pads AND rotors are covered.
Old 11-22-2008, 07:42 PM   #10
Car: 08 SSM STi
Fav Mod: Stock, for now
IWSTI Addict since: Jan 2005
Good info. I was just taking a look around to see what compatibility was like from the GD to GR. I had a set of HPS from my 05 that I never used.
So I'm correct in assuming that the pads I had from my 05 will fit my 08 (front and rear) without any problems?
Old 11-26-2008, 04:51 PM   #11
Car: 08 STI
Fav Mod: Removing the window sticker
IWSTI Addict since: Feb 2007
I switched out the stock pads for HPS, mainly to reduce the amount of dusting. I ran HPS on my 02 WRX wagon and was happy with them. What I didn't expect was how much weaker they were than the stock pads - I could get fade pretty easily driving aggressively. The definitely dusted less, but they are not a performance upgrade, or even an equivalent.
tshrey is offline   Reply With Quote
Old 12-02-2008, 01:52 PM   #12
Fav Mod: Flat soled shoes
IWSTI Addict since: Apr 2008
Has anyone successfully gotten a dealer to replace the '08 pads w/ the earlier model pads under warranty? I really dislike these pads. They're noisy as hell, they make a mess of my wheels in less than 48 hours, and the stopping power just isn't there to justify those issues.
linkbeat is offline   Reply With Quote
Old 12-02-2008, 02:52 PM   #13
Car: 08 SSM STi
Can anyone verify that they will fit w/o issues?
