Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Interior
Old 09-19-2008, 01:13 PM   #1
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Gauges in the 08!
So, one of the things that we do on a regular basis is check out products as something we think we might like to carry. Some make it, some don't. We think this one has a good shot at making it into our offerings so we thought we'd show some pics of how we're checking them out.
This setup is made by PLX Devices and had sensors for boost, EGT, oil pressure, oil temp and water temp installed. One thing we were really looking for in a gauge setup for the 08 was something clean and not out in the middle of the dash. This setup allows me to get most of the info I want on one display. Clean and simple.
It is also customizeable in many ways. I changed the colors of the numbers and needles to match the cluster. You can also do custom gauge faces so that you can make your own gauges with pictures or whatever. You also get conditional warning functionality that is more advanced than anthing I have ever seen. You can really do some crazy warnings with it. It will also display peak values.
Down below you can see the sensor array or what we have come to call "the bomb" for obvious reasons. It looks like a wiring nightmare, but is not that bad. All of the sensor block daisy chain together with only one wire going to the gauge display. Keeps it easier this way. You can also add on additional display modules very easily if you ever wanted to see more at one time. One really cool thing about this is you can add an OBD interface to read OBD info on the normal gauge display. I am thinking of adding one of these to be able to read some items from the ECU.
I went simple on the mounting. I made a small L bracket that just slips between the cluster surround pieces. It holds in place very well, looks clean, is out of the way and was very easy to do.
Old 09-19-2008, 01:43 PM   #2
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
IWSTI Addict since: Feb 2008
Default Re: Gauges in the 08!
Dear Santa,
Please give me one of these for Christmas.
Edvig is offline   Reply With Quote
Old 09-19-2008, 01:50 PM   #3
Fav Mod: Advan RS 18x9. TurboXS downpipe.
IWSTI Addict since: Jan 2008
That is pretty cool. The gauge's housing itself looks a bit flimsy/cheap, but the functional capabilities are quite nice.
paikman is offline   Reply With Quote
Old 09-19-2008, 01:52 PM   #4
Trader Rating: (53)
It's on par with pretty much any other gauge I have installed (most that is).
There have been a few people who have removed the screen from the gauge and put it in their rear view mirrors. Thought about it, but it really wasn't much in my line of sight.
Old 09-19-2008, 02:49 PM   #5
Car: Silver 08 STI(stock)
IWSTI Addict since: Dec 2005
Send a message via AIM to sutter2k
what kind of price range are we talking here?
sutter2k is offline   Reply With Quote
Old 09-19-2008, 02:52 PM   #6
Fav Mod: AMR
Hmmm, what's the total cost TIC? I like it since its versatile and I'm hoping the cost is relatively low. The HKS CAMP2 is what I have my eyes on since its relatively total stealth.
pisymbol is offline   Reply With Quote
Old 09-19-2008, 03:09 PM   #7
Car: OBP, 2008
IWSTI Addict since: Jul 2004
Send a message via AIM to method
They have been out for quite some time, more information here: PLX Devices Inc. - Custom Digital Gauges, Wideband O2 Air Fuel Ratio, OBD 2, Data Loggers Great products, a local guy runs them.
method is offline   Reply With Quote
Old 09-19-2008, 03:31 PM   #8
Car: 2008 DMG STi
IWSTI Addict since: Dec 2007
My question is. Since it is an OBII connection guage, do you have to un-plug it when you shut down the car like the AP and then plug it back in after you start the car?
1day is offline   Reply With Quote
Old 09-19-2008, 03:45 PM   #9
Car: 08 STI
Fav Mod: Harman Motive & Topspeed
IWSTI Addict since: Apr 2008
how difficult would the installation be for a beginer? That looks like a lot of wires!!
Krusader_08_STI is offline   Reply With Quote
Old 09-19-2008, 05:45 PM   #10
Trader Rating: (53)
It is a lot of wires!!! Each sender has it's own power and ground. The small round cables you see between them are for the daisy chain connection. Then you have the actual sensor inputs. I probably spent a total of 6 hours or so installing them with taking time to be cautious about the wiring.
Old 09-19-2008, 05:48 PM   #11
Trader Rating: (53)
Yes, a few years now. Never really seen them get much press here though.
Retail price for this setup is 721. Not bad considering what you get. Price per gauge is definitely less than something like a Defi setup and there is much more functionality built in.
Old 09-19-2008, 05:49 PM   #12
Trader Rating: (53)
That is just the way the AP is wired. We have units that will read off the OBD and will shut down with the car. I'm sure this one would shut down and start up with the car's ignition.
Old 09-20-2008, 09:01 AM   #13
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
that thing looks awesome.
Old 09-20-2008, 10:14 AM   #14
Car: OBP, 2008
From what I have seen in person you don't really see the screen cutout unless in really bright or direct sunlight conditions--it normally looks round..
Old 09-20-2008, 12:04 PM   #15
Trader Rating: (53)
Yeah, for the most part I don't see it.
