| Amateur STI Driver Car: White 08 WRX STi Fav Mod: COBB STG 2,INVIDIA DP Location: San Juan Capistrano Ca Posts: 26
IWSTI Addict since: Jan 2008 Trader Rating: (0) | Whats Up Everyone Just Got My Cobb Ap This Past Weekend And Installed The Stage 2 Map. Since I Installed The Map And I Feel It Hesitate When I Take Off From A Stop In [i] Mode Just Wondering If You Guys Have Any Suggestion On What Might Be Going On??? Also I Was Wondering How To Get The Launch Control Function Wworking??? Thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Gold Member
Car: '07 CMG STI Fav Mod: Not knowing how to "spell" hah Location: los angeles Posts: 3,924
IWSTI Addict since: Aug 2006 Trader Rating: (15) | You're ecu needs to learn for a few days. When ever you reset the ecu the throttle input will be very sluggish. Some spirited driving and a couple hours, and it should be back to normal. As for launch controll, go on you're ap. Go to settings, lc, then set it to you're desired launch rpm. Don't set it too low, or it will affect you WOT shifts. I would say above 5k and you're fine. Good luck! |
| | #4 |
| Senior STI Driver
Car: 08 WRB STI Fav Mod: me driving it Location: NJ Posts: 347
IWSTI Addict since: Mar 2008 Trader Rating: (0) | Stage 2 map requires a turbo back or a downpipe. Don'y know if you have it on your car. |
| | #5 |
IWSTI Addict since: Jan 2008 Trader Rating: (0) | As for launch controll, go on you're ap. Go to settings, lc, then set it to you're desired launch rpm. Don't set it too low, or it will affect you WOT shifts. I would say above 5k and you're fine. Good luck! I SAW WHERE IT IS AT BUT IT SAYS SOME THING ABOUT THE FEATURE NOT BEING ENABLED ON THE MAP Stage 2 map requires a turbo back or a downpipe. Don'y know if you have it on your car. I HAVE AN INVIDIA DP InTALLED too. Last edited by flowsti; 09-17-2008 at 05:35 PM. |
| | #6 |
| Gold Member
IWSTI Addict since: Aug 2006 Trader Rating: (15) | Ok that means you need to update the firmware on you're ap. Cobb updates it like once a week, soo annoying! Just go to cobbs website, and follow their directions for the firmware update.. You'll be happy you did! |
| | #8 | |
IWSTI Addict since: Jan 2008 Trader Rating: (0) | Quote:
any info would be helpful. thanks FLowSTi | |
| | #9 |
| Senior STI Driver Car: OBP 05 STi Fav Mod: 07 STi Head Unit Swap Location: Modesto, CA Posts: 364
IWSTI Addict since: Apr 2007 Trader Rating: (0) | You have to flash your ECU with a Launch Control Enabled map. Once you've done this. The options should work. The LC maps are clearly marked on the map download page. You need to download the maps and add them to your AP. Then you can flash your ECU, and you should be able to set the LC parameters. Hope this helps |
| | #10 | |
do i have to get it protuned to get a LC map or can i get one from cobb????? | |
| | #11 |
IWSTI Addict since: Apr 2007 Trader Rating: (0) | CobbTuning.com - Subaru AccessPORT Find the maps for your year of car. There will be a Yellow LC for launch enabled maps. You don't need to be tuned to use LC maps. Just download them, add them to your other maps, send it to your AP flash your ECU |
| | #12 | |
| | #13 |
| Gold Member
IWSTI Addict since: Aug 2006 Trader Rating: (15) | Possibly, I don't see why not. |
| | #15 |
| Friendly Lurker Car: 08 STI Fav Mod: RCE Camber Plates Location: Maryland Posts: 2,047
IWSTI Addict since: Mar 2008 Trader Rating: (0) | ^^^+1 This ad is not endorsed by this member. Please register or login to hide this ad. |
