| Professional STI Racer | If someone can figure out the wires necessary to run a boost gauge through the stereo I can do a write up on Thursday (if that is even an incentive) Does anybody know which wire goes where back there? Thank you, Chris This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| S204 Racer Car: 05 OBP STi Fav Mod: My Right Foot Location: Rockville, MD Posts: 2,545
IWSTI Addict since: Oct 2004 Trader Rating: (1) | Do you mean, like using 12v source through stereo harness? Why not just use the 12v source in the clock harness. I believe that's what 99% of the people use. |
| | #3 |
| Professional STI Racer | 08 Harness is different from what I've heard. I've plugged the clock harness on my previous gen's but was told it's either too hard or impossible to do on the 08. Does anyone have a write-up on the clock harness? |
| | #4 |
| Junior STI Driver | i dont know if the 08's are quite the same, but you can also try the cigarette lighter. i ran my boost gauge off that in my 07. |
| | #6 |
| Silver Member Car: OBP 08 STI Fav Mod: AccessPort Location: NJ Posts: 94
IWSTI Addict since: Jan 2008 Trader Rating: (1) | I powered my gauge off the clock on my 08. I just used a multimeter to figure out which one was what. I bet you are going to ask me which ones I used now, don't remember. I guess i could pull out the head unit to see if you really need it. Definitely not impossible. |
| | #7 |
IWSTI Addict since: Jan 2008 Trader Rating: (1) | Please double check the wires using a multimeter so you don't break anything. Also note that I had trouble getting a good ground from the clock so I used the headunit ground wire. For the ground wire i tapped the ground wire on the back of the head unit. The color of that wire is black/blue. ![]() For 12V i tapped the blue/red wire from the clock. ![]() For the ignition wire I tapped the brown/white wire off the clock. ![]() For the illumination wire i tapped white/purple wire off the clock. Sorry this one is hard to see. ![]() This is a pic of the defi wiring harness just as a point of reference. Orange=Ignition Red=12V White=Illumination Black=Ground ![]() and just for fun ![]() Last edited by sleepyhead; 09-16-2008 at 01:38 PM. |
| | #9 | |
| Senior STI Driver
Car: 08 STi WRB/Gold Fav Mod: Hatchback! Location: SF Bay Area Posts: 388
IWSTI Addict since: Jun 2005 Trader Rating: (0) | Quote:
Thanks for the pics you posted up. Quick question, i'm guessing you are getting a single gauge sweep with those hookups? I'm getting the dreaded double sweep with mine (once ignition on,again on startup), and need to get in there and re-wire. | |
| | #10 |
IWSTI Addict since: Jan 2008 Trader Rating: (1) | I installed mine a few months ago so its a bit cloudy but it i do remember seeing it sweep more then once or just blink and do nothing. It was acting quite shady and I had confirmed multiple times with a multimeter the ground i was using. I eventually gave up and just used the standalone ground on the head unit and it worked great. This ad is not endorsed by this member. Please register or login to hide this ad. |
