Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Tires & Wheels
Old 09-13-2008, 09:49 AM   #1
Car: '08 WRB STi
IWSTI Addict since: Mar 2008
Default Help - Quick question re stock Dunlop tire
I'm such an idiot - I took my wheels off to clean them and did not take note of proper orientation for putting them back on. Duhh!!
They are back on, as follows: Wider of the 4 sets of tread on the outside. So, from outside in: wide tread set, narrowish (pair of) treadless band, narrow tread set, narrow tread set. Forgive my amateurish description, for that is what I am,
Is this right? I was at the dealer last week and this did not seem to match what they had on the '09 STis that are now in stock.
Could someone please advise me on correct orientation? Also, what is the best technique (other than memory) of keeping track of which wheel goes where when they are removed for cleaning, storage, etc.
Thanks very much
Smiley is offline   Reply With Quote
Old 09-13-2008, 10:18 AM   #2
Fav Mod: Fuel
IWSTI Addict since: Apr 2008
Default Re: Help - Quick question re stock Dunlop tire
The stock SP600 is not directional (just found this out myself) so unless you took the tires off your wheels and remounted, you're fine.
People mark their tires with either a grease pencil or chalk.
You could also mark your wheel with some painters tape or something like that.
Edit - specifically answering your question - wider tread blocks on the outside
see this pic from tirerack
Slimey is offline   Reply With Quote
Old 09-13-2008, 10:43 AM   #3
Car: 08 STi
Fav Mod: soon to be AP
IWSTI Addict since: May 2005
Send a message via AIM to bigd
Unless that is, you've found some way to mount the wheel backwards... lol look at that DISH!
All 4 tires are identical and non directional, but there IS an inside outside. The wider blocks are the outside edge. As Slimey stated, you have nothing to worry about unless you actually unmounted the tires from the wheels (i.e. mount and balance).
If anything, you may want to mark them as stated above to maintain tire rotation position for each corner, (i.e. LF, LR, RF, RR). This way they get rotated correctly when the time comes.
bigd is offline   Reply With Quote
Old 09-13-2008, 11:14 AM   #4
Car: '08 WRB STi
Thanks guys.
I wasn't aware they not directional.
Are there any likely impacts to changing left and right hand sides?
Thanks again.
