Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Suspension, Handling, Stiffening
Old 09-12-2008, 02:23 PM   #1
IWSTI Addict since: Jun 2006
Default Anyone have part numbers on the rear 17mm nut/bolt combo on the suspension?
Seeing as my socket won the battle over the nut connecting the lower part of the shock to the control arm, I'll need to be replacing those pronto.
Subaru needs (or at least the parts guy was too "busy" to look) a part number to be able to see inventory on said nut, but I was clueless. Anyone here have any idea?
Thanks in advance,
Chris
Old 09-12-2008, 02:27 PM   #2
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
Default Re: Anyone have part numbers on the rear 17mm nut/bolt combo on the suspension?
Originally Posted by fullerton View Post
Manchurian
Jamie from SubaruGenuineParts.com || Where Genuine is Better! got me all these part numbers. Now I can bolt up my WL lateral links and use fresh bolts on my COs when I change settings. I'll also be replacing my slightly torn Fender Liners.
(ordering bolded)
ALL FOR GD STIs.
Front eccentric/camber bolts
• 20540pa010 (2x)
• 20560aa040 (2x) Washers
Plain hub to strut bolts
• 901660036 (4x)
Nuts for hub to strut connection
• 20550AA010 (6x)
Lateral link hardware
• 20584A (2x) 20560AA030 (washer)
• N350006 (4x) 902350006 (Inboard nut)
• 20584C (2x) 20560AA011 (Washer)
• 20584B (2x) 20560AA000 (Washer)
• 20568 (2x) 20550AA010 (links to hub nut)
• L33505X (4x) 900335056 (Washer)
• 20578D (2x) 20540AA001 (Long Bolt)
• MO0011 (2x) 901000110 (Inboard front eccentric bolt)
• 20578 (2x) 20540AA111 (Inboard Rear bolt)
FENDER LINERS
• 59110FE062 RH (Liner)
• 59110FE072 LH (Liner)
• 46064AE000 Need - 10 (Clips)
• 59122FA010 Need - 8 (Clips)
• 57728AC090 Need - 4 (Clips)
Hope this helps... the bolt/nut is in there somewhere.
Old 09-12-2008, 02:30 PM   #3
You really are a great person.
Old 09-12-2008, 02:33 PM   #4
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
Now buy the part from Jamie!
Old 09-12-2008, 03:38 PM   #5
I just emailed them and already got a response. Just waiting for pricing/order info
Thanks again man
Old 09-12-2008, 04:27 PM   #6
Fav Mod: hammer down!
IWSTI Addict since: Jun 2008
Aren't those the part numbers for a pre-'08 car? There are no "lateral links" on the '08. The OP is looking for the bolt for the connection from the lower shock end to the lower lateral control arm. I'd help, but the shop manual download site doesn't have the parts database and I haven't found another way to get a copy yet. You could dig through the pages on Jamie's site, but they are slow and seemingly incomplete.
Frank
Old 09-12-2008, 06:59 PM   #7
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
ohhh... you have a good point. didn't notice this was for an 08.
fwiw, all 08 owners should note that, regardless of posting in the 08 areas or not. i found this via new posts as most do.
anyway, jamie will help you out.
