Old 09-12-2008, 12:02 PM   #1
Car: Obsidian Blk 08 STi
Fav Mod: AMR Dual Turboback :)
IWSTI Addict since: Aug 2008
Default Reverse ring thing
I'm having more problems with my STi. Just right now when I was coming back from work I was reversing out of the parking lot. For some reason the ring you pull up to reverse is stuck in the up position now. Why is it doing this??? I'm taking this problem to the dealer also, but I'd like to know why it's stuck now. Im kinda scared to drive it now, because I don't wanna be going 60 on the free way and then accidentally shift into reverse . So many problems at 800 miles already, now the little cover that covers your trunk is vibrating really bad. Im really hoping I didn't get a lemon....
Im2ninja4u is offline   Reply With Quote
Old 09-12-2008, 12:42 PM   #2
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
IWSTI Addict since: Feb 2008
Default Re: Reverse ring thing
The reverse lock out cable might be kinked or jammed in some fashion. You can check it under your car.
Edvig is offline   Reply With Quote
Old 09-12-2008, 12:44 PM   #3
Car: AW 08 STi
Fav Mod: USA for MOD
IWSTI Addict since: Jun 2008
Can you push it back down?
ccc187307 is offline   Reply With Quote
Old 09-12-2008, 12:50 PM   #4
Car: 04 WRB sti
IWSTI Addict since: Apr 2007
yes this^^^^^
lapinga is offline   Reply With Quote
Old 09-12-2008, 01:48 PM   #5
Fav Mod: Britax Roundabout
IWSTI Addict since: Jan 2008
wait, we have 6 gears??
Old 09-12-2008, 01:55 PM   #6
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
IWSTI Addict since: Nov 2007
i was waiting for that
Wales Garage is offline   Reply With Quote
Old 09-12-2008, 02:11 PM   #7
Car: WRB 03 STi Spec C
Fav Mod: All of them...
IWSTI Addict since: Sep 2006
I had a friend who had a similar problem with his s2K. But bear in mind, the s2k requires you to push the lever down to engage reverse. When he pushed the lever down, it wouldnt go back up. Later he found out that there was air bubbles in the clutch lines, and when he 'burped' the system, everything was fine again. maybe you can try this...
joe13 is offline   Reply With Quote
Old 09-12-2008, 02:21 PM   #8
Fav Mod: ohlins w/RCE springs, sz55
IWSTI Addict since: Nov 2005
Send a message via Skype™ to elirentz
^definitely not it the s2k is completely different.
I would be willing to bet its either the pin that holds the ring that is getting caught in the ball of the shifter, the cable, or its on the linkage connected to the tranny. I had a problem with the first one on my 05. Definitely make the dealer take care of it though.
elirentz is offline   Reply With Quote
Old 09-12-2008, 03:54 PM   #9
Yes I can push it back down, but it springs right back up. Pushing it down doesn't stop me from reversing either.
Old 09-13-2008, 04:57 AM   #10
Car: 2008 SSM WRX STI
IWSTI Addict since: May 2008
Hi Ninja, my advice is to take your STI to the dealer for evaluation. Please see my previous post here: http://www.iwsti.com/forums/2008-sti...o-reverse.html
They had to perform a total teardown on my transmission because it would not shift into reverse. Once they completed the repair, however, the car seemed to shift better, more accurately. Good luck!
There! is offline   Reply With Quote
Old 09-13-2008, 06:26 AM   #11
Fav Mod: Me.....
IWSTI Addict since: Jun 2006
do you have a short shifter in the car? if so the lockout cable will rest on the drive shaft and start wearing through the cable.
Old 09-13-2008, 10:29 AM   #12
IWSTI Addict since: Jul 2008
Honestly, are people really this lost? How about calling your dealership and scheduling and appointment? It's not as if this is going to cause any trouble, but you'll want it fixed. I don't understand how this could be so vexing or insurmountable of an issue to not know the proper path of getting it fixed.
Dealer first, message board second!
-Garrett
Garrett is offline   Reply With Quote
Old 09-13-2008, 08:06 PM   #13
Fav Mod: Fujitsubo!!!!!!!!
IWSTI Addict since: Nov 2006
You don't have to slide under the car that far to see it.
from the driver side, slide under the car and that "clip" is located on the driver's side of the clutch housing.
Rennes is offline   Reply With Quote
Old 09-14-2008, 07:53 AM   #14
Your right, actually you don't have to slide under your car for anything... because you bought it from a dealership!
-G
Old 09-14-2008, 07:58 AM   #15
Thanks guys, taking it to the dealership on monday.
