Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-I.C.E/Security
Old 09-10-2008, 07:51 PM   #1
Car: 08 STi
IWSTI Addict since: Jul 2005
Send a message via AIM to Pkskull77
Default 2008 Stereo Install Wiring Diagram
I'm getting ready to install an aftermarket stereo on my 2008 STi and I'm wondering if any of you have a wiring diagram for the stock stereo (non-navigation).
I could figure it out through trial and error, but I'd rather go into the process knowing what I'm getting into.
Any help would be appreciated.
Thanks
Pkskull77 is offline   Reply With Quote
Old 09-10-2008, 08:06 PM   #2
Car: Silver 2008 WRX STI
Fav Mod: Rear Tints & Magnaflow.
IWSTI Addict since: May 2008
Default Re: 2008 Stereo Install Wiring Diagram
Thanks
Same here, please anyone.
zoth is offline   Reply With Quote
Old 09-11-2008, 05:34 AM   #3
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
There are two good threads on nasioc that go into detail about this. search 08 and AVIC in the car audio forum and you will find them.
Old 09-11-2008, 05:48 PM   #4
Car: 08 STi
I believe that this is the post your talking about.
NASIOC - View Single Post - The 1st comprehensive 2008 impreza dash & radio removal guide
This seems to be up to snuff. I'll be soldering this weekend, and will let you know if all goes well. Thanks for your help.
Old 09-14-2008, 09:54 AM   #5
Car: 08 STi
The wiring diagram listed above is accurate, with one small note.
I don't know if this occurred because I had the factory bass upgrade, but the wiring harness referenced above was not connected to the back of the stereo. There were also some additional ground wires connected to the side of the stereo.
When I followed the wiring harness connected to the stereo back a bit I found a second harness. The second harness was an exact match for what is posted above. I solder the stereo harness in accordance with the link posted above, and connected to the second harness, not the first one that was connected to the stereo.
Everything worked perfectly.
Old 09-14-2008, 10:59 AM   #6
Car: OBP, 2008
IWSTI Addict since: Jul 2004
Send a message via AIM to method
method is offline   Reply With Quote
Old 09-14-2008, 11:20 AM   #7
Originally Posted by method View Post
Thanks.............
