Old 09-06-2008, 07:59 PM   #1
IWSTI Addict since: Sep 2008
Default 100 octane in stock 2009 wrx sti
Howdy everybody,
Newbie Here
I searched, but couldn't find out if it is OK to run 100 octane in a completely stock 2008....saw lot's of info on the Cobb Stage 1/2. Safe to do, warranty problems, etc. I'm saving for the Cobb setup but it will be awhile. Thanks for you help.
YosarianRem is offline   Reply With Quote
Old 09-06-2008, 08:02 PM   #2
Friendly Lurker
Car: 08 STI
Fav Mod: RCE Camber Plates
IWSTI Addict since: Mar 2008
Default Re: 100 octane in stock 2009 wrx sti
You'd be fine, but why would you want to do this?
Old 09-06-2008, 08:07 PM   #3
Good question....I've had Outbacks for years. I'm new to the STI My understanding (or misunderstanding) is that one could gain a noticeable performance increase from the higher octane fuel. Correct?
Old 09-06-2008, 08:25 PM   #4
IWSTI Addict since: Jul 2008
Incorrect, you loose performance if you run your car with less-than-intended Octane.
This is engine was meant for 93 Octane to run optimally. 91 can be used because the engine's EMU can retard timing enough to stop engine knock (detonation). So, for added protection and anomalies in gas, it is prudent just to use 94 octane.
96+ Octane will do nothing for you, unless you have aftermarket mods or tunning that can make use of it.
-Garrett
Garrett is offline   Reply With Quote
Old 09-06-2008, 08:31 PM   #5
Car: 08 STi
Fav Mod: soon to be AP
IWSTI Addict since: May 2005
Send a message via AIM to bigd
From what I have come to understand, higher octane fuel doesn't give you more power by itself, instead its more stable. This means the engine can be tuned more aggressively (i.e. timing, boost, etc) to take advantage of it.
Lower octane fuels detonate more easily (pre-ignite, knock, ping, etc). For instance, the piston compressing the mixture causes the mixture to heat up before the spark happens. This may force the fuel to ignite prematurely and attempt to force the piston down before it gets to top-dead-center (TDC). This eventually results in engine damage since its essentially fighting itself. A more stable fuel (higher octane rating) can handle this better and instead ignite when the spark happens, which is when the ECU says it's supposed to ignite.
There's other ways to increase a fuel's octane rating instead of just running higher octane fuel such as water/meth injection. I'd stick with 91/92/93 octane pump gas since its available everywhere.
So, without tuning, you may not see any performance increase at all. I could be wrong.
bigd is offline   Reply With Quote
Old 09-07-2008, 07:28 PM   #6
Fav Mod: AMR
IWSTI Addict since: Feb 2008
100 octane will only yield you power if you go to the dyno and retune the car for it. Though I would recommend other modifications to give you more power than just 100 octane fuel.
pisymbol is offline   Reply With Quote
Old 09-07-2008, 07:45 PM   #7
Car: Totalled 06 WRX TR
The only time I could see justifying 100 octane is if you are gonna track it. 93 octane goes a long way believe it or not. Just dumping in 100oct gas won't give you an increase, actually with most cars it hurts performance. The best octane for your car is what it's tuned to use. Be warned, unless it's a dedicated track car I wouldn't get it tuned purely for 100oct, that gets expensive fast and at least around here 100oct is hard to come by- you'd probably end up stuck on the side of the road of you're low on gas and far from home or any place that sells 100oct
EtoS is offline   Reply With Quote
Old 09-07-2008, 08:00 PM   #8
Car: 07STi-DOB-FRI-13-06
Fav Mod: Bullet proof windows
IWSTI Addict since: Dec 2007
07 STi tuned for 93 octane.
Example fill up when on empty;12 or 11 gal of 91 as no 93 here in cali.
Mixed with approx. 3 gal. of 100 octane. to adhere to 93 tune.
Am i doing something wrong? I notice a big difference if i dont do this mix. Albeit placebo affect is very real.
VROOM293 is offline   Reply With Quote
Old 09-07-2008, 09:39 PM   #9
-Garrett
huh
Old 09-07-2008, 09:55 PM   #10
Close enough if it's 12 gallons of 91 to 3 gallons of 100(92.8 octane). BTW the best way to get a good mix is to put the 100 octane first before the 91.
Old 09-08-2008, 05:27 AM   #11
huh
Yes, that is everything you need to know in a nutshell of how and why..! Octane is no mystery and it doesn't need to be complicated to understand.
-Garrett
Old 09-08-2008, 07:00 AM   #12
Car: Not yet. SOON!
IWSTI Addict since: May 2008
huh
Exactly what Garrett said.
The engine is designed for 93.
You run it on 91, the computer retards the timing (not sure about boost, depends on how Subaru tuned it) so you lose some power.
You can put in 94+ in case you want to be prudent. e.g. bad batch of 93 gas or extra hot and stressful operating conditions.
ake109 is offline   Reply With Quote
Old 09-08-2008, 09:30 AM   #13
Our CA. piss at the pump offers 91 then 100 @3 stations in all of L.A.
brentwood 76 ,playa del rey 76 ,barrington 76.
NO 94.I wish we were so lucky!
I cant wait to put real 93 in my tank,as my car has never had the pleasure .
Old 09-08-2008, 09:33 AM   #14
Thanks for the breakdown and tip.
Old 09-08-2008, 09:54 AM   #15
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
IWSTI Addict since: Apr 2006
I just sent this link to a MOD to suggesting to stick it, good link to calculate octane and final price of gas tank.
How to determine octane when mixing 91 and 104 gas??
BBBsti LTD is offline   Reply With Quote
