Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Tires & Wheels
Old 08-25-2008, 11:30 AM   #1
Car: 08 STI DGM
Fav Mod: Fiancé
IWSTI Addict since: Jul 2008
Default Time to rotate tires?
When is a nominal period to rotate the tires on the 08 STI? And our stock asymmetrical tires are ok to rotate crossed correct?
FlashEngineer is offline   Reply With Quote
Old 08-25-2008, 11:43 AM   #2
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
IWSTI Addict since: Nov 2007
Default Re: Time to rotate tires?
i do mine every 3k miles
Wales Garage is offline   Reply With Quote
Old 08-25-2008, 11:49 AM   #3
Car: 08 STI DGM
Fav Mod: Fiancé
So do them when oil changing... k
Old 09-02-2008, 09:13 AM   #4
Car: 08 OBP STi
bingo
Old 09-02-2008, 10:07 AM   #5
Puk, puk, puk!
Fav Mod: SSR Type C/Dunlop 3D Winter Set
IWSTI Addict since: Apr 2008
Manual has it at every 7500 miles.
If the suspension is otherwise stock and car is a DD, is there really a need to rotate more frequently?
To the OP - I'm pretty sure our tires are directional, so only rotate front to back (unless, of course, you want to unmount the tires with every rotation).
Slimey is offline   Reply With Quote
Old 09-02-2008, 10:40 AM   #6
jph
Car: the wagon
IWSTI Addict since: Apr 2004
i'm around 6000 miles, rotated them twice so far.
once when i washed it, the other time when i was installing new pads
J.
jph is online now   Reply With Quote
Old 09-02-2008, 11:01 AM   #7
Car: AW 08 STi
Fav Mod: HPDE
IWSTI Addict since: Jan 2008
tires are not directional, they can rotate anyway you want but they do have an outside and an inside.
subielife is offline   Reply With Quote
Old 09-02-2008, 12:07 PM   #8
Car: Silver 08 STI
every second oil change
jrdriller is offline   Reply With Quote
Old 09-02-2008, 12:11 PM   #9
Car: Silver 04 WRX STI
IWSTI Addict since: Aug 2008
Send a message via MSN to bap2086
whats the exact proper method to do it? i just wanna make sure im doing it properly.
bap2086 is offline   Reply With Quote
Old 09-02-2008, 12:46 PM   #10
Car: Silver 08 STI
IWSTI Addict since: Dec 2007
I doubt my tires will last that long. I rotated at 3K, and I expect to get about 6K from them.
DrPhyzx is offline   Reply With Quote
Old 09-02-2008, 01:31 PM   #11
Car: LR 08 STI
Fav Mod: MT1 Matte Grey 18x8.5
IWSTI Addict since: Dec 2006
I do it every other oil change, so every 6000 miles. The method used (front back or left right) depends on the tires, I would check your manufacturers website for instructions, or just ask your tire guy.
USNSTI is online now   Reply With Quote
Old 09-02-2008, 05:35 PM   #12
Puk, puk, puk!
My mistake. I thought they were directional.
Here is the recommended rotation pattern and time interval from the '08 owner's manual.
Old 09-02-2008, 08:01 PM   #13
Car: Silver 08 STI
Just checking but, usually tire rotations are recommended for even wear since most cars are either Front or Rear wheel drive.
Now with an all wheel drive, given its left at 50% front to rear, why would tire rotation be needed since all four tires are given the same amount of torque? Is this true or am I off base?
PHXSTI is offline   Reply With Quote
Old 09-02-2008, 08:19 PM   #14
Puk, puk, puk!
There are still weight and suspension loading differences front to back...as well as that thing up front called the steering rack.
Old 09-05-2008, 10:40 AM   #15
Car: '08 WRX STI Stage 1
Fav Mod: I don't know any of the mods on this forum.
That's what I do. It fits nicely with every other oil change. I got very even wear out of the tires on my '05 WRX with this method. I also got 40k miles out of the stock tires. Not expecting that with the STI.
yakkosmurf is offline   Reply With Quote
