Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 08-22-2008, 08:26 PM   #1
_
IWSTI Addict since: Mar 2008
Send a message via AIM to Spaceman Send a message via Skype™ to Spaceman
Talking Now Available: 2008 STi Bumper Removal/DRL Disable How To
In case some of you don't check the how to forums I compiled a how to remove the front bumper.
I know there have been many inquiries about this.
http://www.iwsti.com/forums/how-inst...ml#post2023586
I also pointed out the Intake Silencer and DRL Disable in this How To.
And an older one...
How To: Paint STi logo on intercooler
Spaceman is offline   Reply With Quote
Old 08-22-2008, 08:34 PM   #2
Car: 08 blue sti
Fav Mod: reflash
IWSTI Addict since: May 2008
Default Re: Now Available: 2008 STi Bumper Removal/DRL Disable How To
Thank you thank you! So simple once you have done it :-)
brookslarry is offline   Reply With Quote
Old 08-23-2008, 10:39 AM   #3
Car: 2005 & 2008 STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
IWSTI Addict since: Mar 2005
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
On the 05+ LGT's there's a relay under the dash on the driver's side that you can disconnect to do away with the DRL's. Should be the same on the 08 STI's. I'll check it out later.
JDM-STI is offline   Reply With Quote
Old 08-23-2008, 08:08 PM   #4
LaW
Fav Mod: Harman Motive Sway Bars
Wrong, its actually right in front of the passenger side front wheel behind the bumper.
BUMPER REMOVAL NOT REQUIRED.
The front passenger side bumper vent slides right off and gives you easy access to the plug to disable the DRL's... Its VERY easy! Should take less than 1 minute
LaW is online now   Reply With Quote
Old 08-24-2008, 12:20 PM   #5
Yeah, that's the wire harness plug. I was looking for the in car relay that we unpluged on the LGT's. It's in a different location apparently on the 08 STI. Because it wasn't there when I looked yesterday. That same harness plug could be unplugged on the LGT's. Most unplugged the inside relay instead. I was just looking for the easier way.
