| Amateur STI Driver | Just got a Defi Boost guage installed from a local shop. Car is completely stock except and is showing 16psi of boost at full power? Is this normal? I thought stock was 14.7psi? Also car has 900 miles on it. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Amateur STI Driver Car: White 08 STi Fav Mod: Coming Soon Location: Philippines Posts: 26
IWSTI Addict since: Apr 2008 Trader Rating: (0) | 08 STI, have a catless DP and exhaust - on my boost gauge, peak is usually about 17.5 psi. Check engine comes on at 19psi FYI. Never checked stock boost though stock tune btw |
| | #3 |
| Amateur STI Driver | I just ran my car up to 6200RPM and the boost stayed steady at 16PSI. Is this normal? I thought that boost should start falling after 5500RPM. Any ideas? |
| | #6 | |
IWSTI Addict since: Apr 2008 Trader Rating: (0) | Quote:
After a reset, all is well, should just remember not to do a flat out run in 6th gear ![]() I'm using a Sard electric gauge w/peak hold btw | |
| | #7 |
| STI Driver | I have a stock 06 with the same guage setup. My car will hit around 16psi from 3rd gear on and about 13.5-14.5psi in 1st and 2nd. The guage will hit around 16psi for a second but then tapers to about 15psi. It's hard to notice the taper unless you're viewing a recorded run and looking at the guage straight on (not from an angle). It also depends on when you go WOT. For example, I've seen the gauge spike to a little over 16psi if I go WOT in 5th or 6th gear from low rpms (not recommended), but I still get the taper. |
| | #8 | |||
| Amateur STI Driver | Quote:
THANKS EVERYONE!! GREAT FEEDBACK. This ad is not endorsed by this member. Please register or login to hide this ad. | |||
