Old 08-02-2008, 12:46 AM   #1
Car: White 08 WRX STi
Fav Mod: COBB STG 2,INVIDIA DP
IWSTI Addict since: Jan 2008
Thumbs down CEL turned on after DP install NEED HELP
hey guys i just installed an invidia Catless DP I was out driving around getting the car used to it and after 1-130 hours later my CEl turned on my S light and my cruise control light started flashing i was just wondering if you guys had any idea what went wrong?
flowsti is offline   Reply With Quote
Old 08-02-2008, 12:50 AM   #2
Banned
Fav Mod: brown chicken brown cow
IWSTI Addict since: Mar 2008
Default Re: CEL turned on after DP install NEED HELP
catless dp will trigger a p0420. Catalyst System Efficiency Below Threshold.
ecu is sensing you no longer have a cat. you need a mechanical cel fix.
Rear O2 Sensor mechanical fix for CEL code P0420 - ScoobyMods
mattjk is offline   Reply With Quote
Old 08-02-2008, 12:52 AM   #3
Car: 02 AW Bugeye
Fav Mod: Cusco V-Brace
IWSTI Addict since: Jun 2008
cel turning off after a catless downpipe would usually have something to do with the o2 sensor. There are different ways to fix it that I'm sure someone could explain better than i could. I know there is a mechanical way to fix it where you move the o2 sensor out of the exhaust flow, and you can fix it electrically as well with some sort of resistor.
^ what he said
numberseven is offline   Reply With Quote
Old 08-02-2008, 01:50 AM   #4
Car: 2004 PSM STi
Fav Mod: STi floor mats
IWSTI Addict since: Mar 2006
when i installed my DP i just drilled out a spark plug anti-fouler with a 1/2" bit, put that in the DP bung, and put the o2 sensor into that = no CEL. i dont know if this woulda prevented the code you're getting but either way, i've never had a CEL.
uptheundagrnd is offline   Reply With Quote
Old 08-02-2008, 05:38 AM   #5
Car: 05 STi - Black
Fav Mod: No Lien
flowsti,
you need to buy engine management with that downpipe ASAP. I'm an surprised people still do no know this.
05_GD7 is online now   Reply With Quote
Old 08-02-2008, 07:38 AM   #6
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
The Cobb stage 2 map suppresses that CEL code.
Old 08-02-2008, 08:46 AM   #7
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Get some kind of engine management!!
Old 08-02-2008, 08:52 AM   #8
i eat cones
Fav Mod: intake
IWSTI Addict since: Oct 2006
Trader Rating: (21)
please tune it....
Old 08-02-2008, 08:58 AM   #9
Car: 07 STI
Fav Mod: Zzyzx Coilovers
IWSTI Addict since: Jul 2007
google search eh.
How about some EM instead.
Old 08-02-2008, 09:46 AM   #10
Banned
Originally Posted by JD_STI View Post
google search eh.
I did that mod back in 2002, before there were any reflash options!
DIY CEL Fix. - NASIOC
I was under the assumption, that even though the code for p0420 is suppressed by say a Cobb AP, the ecu will send a PFFFE CEL, which is a pending code.
I'd still rather do the mechanical fix along with a reflash.
Old 08-02-2008, 10:06 AM   #11
i eat cones
Fav Mod: intake
Trader Rating: (21)
the sti is different from the wrx... running without EM can be very bad.
Old 08-02-2008, 10:11 AM   #12
Banned
man, you guys act like you own ferrari's. the two cars run very similar em systems.
Old 08-02-2008, 10:13 AM   #13
Car: 02 AW Bugeye
Old 08-02-2008, 10:17 AM   #14
Car: 07 OBP STI
Fav Mod: AutoSpeed Catback
IWSTI Addict since: Dec 2007
hmm.. no EM, catless DP= Motor goes Pop for the 07s... I figure it will do the same with the 08s... no
PuccasBad_STI is online now   Reply With Quote
Old 08-02-2008, 10:17 AM   #15
Car: 07 STI
It is certainly a mechanical issue, regardless, EM is still needed. Maybe you're mod + EM is the best bet.
