Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 07-30-2008, 08:33 AM   #1
Car: 08 STI
IWSTI Addict since: Aug 2004
Default Right turn signal flips headlights on and off, wtf??
Just like I stated, with full headlights on, the right turn signal turns the HIDS on and off briefly. Anyone ever seen this issue? I'm going to take it by the dealer to see what kind of ghost is in the machine.
kris is offline   Reply With Quote
Old 07-30-2008, 08:55 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Re: Right turn signal flips headlights on and off, wtf??
BAM!!!!!! You win the actual legit problem that's we've never heard of before award!!!!!
You might want to try vwvortex as I understand those guys are good with problems like this one.
OK - no more joking. I think you should take it to the dealer and see what's up.
Old 07-30-2008, 09:04 AM   #3
Car: '05 CGM
Fav Mod: HPDEs
IWSTI Addict since: May 2006
I'm going to guess a bad turn signal/headlight switch or a loose connection between the switch and wiring harness.
Gary
Old 07-30-2008, 09:10 AM   #4
Car: 08 STI
Yeah I searched and I didn't see it. I spoke to a Suby guru up here in Toronto. Apparently someone up here had an 07 STI burn to the ground with the same symptoms...
Old 07-30-2008, 09:23 AM   #5
Trader Rating: (53)
Oh CRAP!!! In that case I DEFINITELY think you should take it in.
Old 07-30-2008, 12:30 PM   #6
Car: 08 Aspen STi
IWSTI Addict since: Jan 2006
Send a message via AIM to Arcticsun
That sounds pretty scary. Similarly my right turn signal will blink fast sometimes for no reason, maybe 2 days in a row, then go back to normal the next day...no idea why
Arcticsun is offline   Reply With Quote
Old 07-30-2008, 04:16 PM   #7
Banned
Fav Mod: brown chicken brown cow
IWSTI Addict since: Mar 2008
make sure your battery terminals are tight.
mattjk is offline   Reply With Quote
Old 07-30-2008, 06:25 PM   #8
Fav Mod: Me.....
IWSTI Addict since: Jun 2006
Whats sad is this is sooooo true....
<--- ex-VW owner
Old 07-30-2008, 06:38 PM   #9
Car: 09 L.L.Bean Forester
Fav Mod: Not having one
IWSTI Addict since: May 2008
TAKE IT IN!!!!!!!!!!!!!!! ASAP!
Nativepenguin is offline   Reply With Quote
Old 11-11-2008, 06:13 PM   #10
IWSTI Addict since: Aug 2006
I have the exact same issue. Right side front turn signal blinks really fast, like there is a short or a bulb has burned out. When I turn the hazards on, though, it blinks at the normal rate. I also noticed that when the turn signal is blinking, one one of the filaments is lit, but when the hazards are turned on, both filaments in the bulb are lit. However, on the right side, where this issue is, only one filament is lit in the bulb. I am going to change out the bulb and see if it makes a difference. Hopefully it is a bad bulb and nothing else. Do not want to spend a whole day at the dealer over a stupid bulb, if I can fix it myself.
kailua is offline   Reply With Quote
Old 11-12-2008, 08:21 AM   #11
Car: 08 Aspen STi
I havn't had this issue since that post. Maybe once the weather cools down I'll see it again. But If I do I must check out the bulb issue!
Old 11-12-2008, 03:17 PM   #12
Ok, so today, I went to Pepboys and bought the replacement turn signal bulb to replace out the one that was buggy. As it turns out the part number in the manual and the charts at Pep Boys is wrong. This is the OEM part and the one I bought is a flat connector.
Anyways, I had to take out the entire airbox, scoop and resonator to access the stupid bulb. It is jammed into the front fender. When I took the bulb out it was not burned out like I originally thought, although it was a bit dusty. Took a can of compressed air and sprayed the contacts down, made sure there was no debris or rust and plugged the bulb back in and tested the turn signal and now it works fine! Crazy!
I am hoping it was just a loose bulb connection and not a greater electrical issue. Put everything back together and started the car. Every single warning light and the check engine light lit up and the "S" mode light flashing.
Made sure the harness for the O2 sensor was connected, disconnected the battery, pumped the brake pedal a couple times to release any residual electricity and let the vehicle sit for about 10 minutes. Reconnected the battery terminal and started the vehicle. All warning light off now and the turn signal is back to normal
I am hoping there will be no more electrical issues. Plus, I really do not trust the local dealer to trouble shoot it correctly.
On a side note, without the resonator (white milk jug part) at over 5000 rpms, the vehicle makes a droaning noise, sound kind of ricey. No improvement in terms of smoothness or power. I will go to Home Depot and find a cap for the hole in the bottom of the intake where the resonator was attached to or just reinstall it. That plastic part, however is really heavy for what it is.
