| Amateur STI Driver | Question - has anyone had any luck getting 2 and/or 4ga cables through the firewall for audio installs? Just curious as to how others have done it. After unstapling the carpet from the side moulding, it looks as though it's still in there pretty tight.. doesn't look as though it's going to be terribly easy to get cabling from the front to the rear of the car. That having been said, I haven't found a good place to run a 4ga through from the engine bay into the car yet, and looking for ideas. Anyone, anyone? Thnx. -Cyan This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Professional STI Driver Car: Silver 08 STI Fav Mod: Coming Soon Location: Santa Cruz Mountains Posts: 488
IWSTI Addict since: Dec 2007 Trader Rating: (0) | My question is... why? The runs in a car are so short that impedance should not be an issue for smaller cables. 2 gauge cable is 0.5 ohms per KILOMETER. That simply doesn't buy you anything unless you are wiring a football stadium. |
| | #3 |
| Amateur STI Driver | I'm perfectly fine w/running a 4ga.. same problem. *where* ![]() I've seen that the passenger side is a good place to go on the 04-07's .. was looking to see if anyone had done something similar on the 08s yet. |
| | #4 | |
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Quote:
American wire gauge - Wikipedia, the free encyclopedia | |
| | #5 | |
| Banned
Car: 2008 wrx sti wrb Fav Mod: brown chicken brown cow Posts: 530
IWSTI Addict since: Mar 2008 Trader Rating: (0) | Quote:
for a car, it is a different animal. where 10ga would be fine to run 120v, for over 300 feet (6amps for a typical 200w amp) the same wire would only be good up to 7 feet at 30amps for a typical 200watt 12volt amp. to go into the trunk, 8ga would be optimal for an amp with a 30amp load. | |
| | #6 | |
| | #7 | |
| Banned
ever try jumping a car with 10ga wire? starters take less than 15 amps and will cook a 10ga wire within 10 seconds. | |
| | #8 |
| Banned
IWSTI Addict since: Mar 2008 Trader Rating: (0) | |
| | #9 | |
![]() ![]() ![]() ![]() So... yes... the question is what is the power draw. Even for a big system shouldn't be more than a few amps, yes? Let's call it 10 amps... that would be about 0.1 W/ft ... should be no problem. Lessee... 15 amp starter through 10 gauge should be 0.225 W/ft. Seriously, that's like 1/20th of a night light lightbulb per foot. That's not going to melt the wire. === I don't have any experience here so I did a quick search: a lot of amps at Crutchfield specify 30A fuses and call out 10 gauge wire for installation... Last edited by DrPhyzx; 07-29-2008 at 01:49 PM. | |
| | #10 | |
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Quote: Now, 40 A in 10 Ga. would be 1.6 W/foot. That's almost half of a night-light bulb per foot, which sounds scary to me without some active cooling. | |
| | #11 | |
| Banned
you're reading it wrong. the first section is AMPS, NOT GAUGE! It says: 10ga wire, 30amps is goog only up to 6.6 feet. | |
| | #12 | |
| Banned
no problem.yes, it will melt. My coworker bought a jumper cable from the 99cents store. It was 10 gauge and it melted, no only the wire but damaged his bumper paint. | |
| | #13 | |
225 mW/foot is not going to melt. | |
| | #14 |
| Gold Member
Car: 04 Platnm Silvr STi Fav Mod: GT35R 450+WHP Pump No Meth Location: MD,BASC Club,Team Agile Posts: 863
IWSTI Addict since: May 2007 Trader Rating: (5) | Run it through the firewall rubber grommet next to the drivers side floor board and run it along the trim panels along the floor back to the trunk, the easiest and cleanest way. Also remove the rear seat for easy access and for routing the power cable/RCA's/Ground. |
| | #15 | |
Please note that the point of that table is not safety issues from melting a wire, but not creating too much power loss (limited to 5%) for solar panels. This is not a solar installation, and that table isn't relevant to the discussion of overheating a wire. This ad is not endorsed by this member. Please register or login to hide this ad. | |
