Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Braking
Old 07-28-2008, 07:07 PM   #1
Car: 08 STI
Fav Mod: Removing the window sticker
IWSTI Addict since: Feb 2007
Default brake pad swap to Hawk HPS
I changed out the front and rear pads to Hawk HPS this weekend. I honestly didn't expect any improvement over the stock pads except in the area of dusting and noise - and that is exactly what I got. You can definitely tell this car is heavier than my 02 WRX wagon; the Hawks were fantastic on that and would never fade in any canyon running that I ever did. By my last 100-0 stop during the bed in process on the new pads I think I started to feel freakin' brake fade! I'm going to flush the fluid when I get a chance.
One question, what is with the anit-squeal plates only covering half the pad and coming across it at an angle? I didn't use the fronts and did use the rear. The Hawks are definitely quieter and dust quite a bit less.
tshrey is offline   Reply With Quote
Old 07-29-2008, 06:44 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Re: brake pad swap to Hawk HPS
A 100-0 bed in on an HPS is not right to begin with. They are street pads. Designed to help your car stop from street speeds. They will fade with hard stops over 70. If you want something that is less prone to fade, get the HP+. They will make more noise and dust more, but definitely have better feel, a higher coefficient of friction and a higher heat range.
That's how the shims have always been with the brembos.
Old 07-29-2008, 01:46 PM   #3
Car: ITS URABUS
Fav Mod: Pagids
IWSTI Addict since: May 2006
Step in to the Blue.....Pagid Blue.
See fav mod.
2slow2curious is offline   Reply With Quote
Old 07-29-2008, 01:50 PM   #4
jph
Car: the wagon
IWSTI Addict since: Apr 2004
or the red... EBC redstuff
J.
jph is online now   Reply With Quote
Old 07-29-2008, 01:55 PM   #5
Fav Mod: GT35R 450+WHP Pump No Meth
IWSTI Addict since: May 2007
See fav mod.
+1 for the Pagid's they are one hell of a pad.
