Old 07-23-2008, 05:56 AM   #1
Car: 08 STI
Fav Mod: Removing the window sticker
Default 2700 rpm stumble on Cobb Stage 2 map?
Anyone else experiencing this? Under moderate loads (normal acceleration with the AC on) I get a hell of a stumble at 2600-2700 rpm. First and second are most notable, probably because you go through the spot so much more slowly in higher gears. I want to see if others are having this same problem before I ask Cobb to take a look.
I know, a protune will take care of it, but I want to do a few more things to the car before a protune and the nearest tuner isn't very close.
tshrey is offline   Reply With Quote
Old 07-23-2008, 06:06 AM   #2
Car: 07 UGM STI
Fav Mod: Cobb AP
Send a message via AIM to ManInABox
Default Re: 2700 rpm stumble on Cobb Stage 2 map?
mine does it as well only when the car isn't warmed up.
ManInABox is offline   Reply With Quote
Old 07-24-2008, 12:00 PM   #3
Car: Dark Grey 08 STI
Fav Mod: Arm rest extender
Originally Posted by tshrey View Post
Anyone else experiencing this? Under moderate loads (normal acceleration with the AC on) I get a hell of a stumble at 2600-2700 rpm. First and second are most notable, probably because you go through the spot so much more slowly. I want to see if others are having this same problem before I ask Cobb to take a look.
Mine stumbled slightly in that range on the the Perrin and Cobb map. Never happened on stage 1.
BTW this only happens when your driving normal and not WOT.
I called Cobb and they said it was normal.
On my latest Perrin S2 map I have had a more pronounced stumble in that same range about 3 times. I may have had the AC on each time, but not sure.
spongebobnopants is offline   Reply With Quote
Old 07-24-2008, 12:15 PM   #4
Car: 08 STI DGM
Fav Mod: Fiancé
Mine does with the cobb 1.01 stage1, and perrin 1.00 stage1, both 93octane. I'm using Perrin rev3 and it has no stumble, that's the only one I would use, I drive way more in part throttle than WOT so I want smoothness, even if the other 2 maps are bit more HP.
FlashEngineer is offline   Reply With Quote
Old 07-24-2008, 12:24 PM   #5
Car: 08 Gray STi
v1.01 of the stage 1 91 octane map does it, too. it's almost as if the turbo comes on boost then backs off. 1st and 2nd are the worst but that simply may be a function of the gearing.
i don't remember it being the case with the v1.0 stage 1 93 octane cobb or the stg 1 93 octane perrin maps i ran before.
Old 07-24-2008, 02:31 PM   #6
Fav Mod: Hatchback!
Y'know, i thought i was just being too sensitive or something, but i do feel mine do that, part throttle, below 3k, 2nd gear usually. Good to know i'm not imagining things, that the slight stumble from time to time is for real. I swear it happens more now in the hot summer days than when i first flashed it.
I'm Stage1, Cobb 1.01, 91ACN
S'poreSTI is offline   Reply With Quote
Old 07-24-2008, 02:45 PM   #7
Car: 08white sti gold bbs
Fav Mod: emblem delete
my car is 100% stock,i noticed it a few times the other day after i reset the ecu.its fine now.i think she is just a slow learner
sleepsindirt is offline   Reply With Quote
Old 07-25-2008, 06:49 AM   #8
Car: '08 WRX STI
Fav Mod: I don't know any of the mods on this forum.
I don't get a stumble, but a bit of a dip in power. You can see it on the Stage 1 dyno graph, which is where I am right now.
yakkosmurf is offline   Reply With Quote
Old 08-08-2008, 03:53 PM   #9
rgt
Car: 07 WRX STI WRB/Gold
Fav Mod: COBB AP Stage 2 93 oct v1.04
Edit.
Nevermind - 08's not 07 ....
rgt is offline   Reply With Quote
Old 08-10-2008, 11:06 PM   #10
Car: PPW 400 whp TTZ
the stumble is the cruise avcs mapping.
HB Speed is offline   Reply With Quote
Old 08-10-2008, 11:27 PM   #11
Car: 06 Subaru WRX STi
Fav Mod: seatbelt beep delete
i really notice a dip when the ac is on, when its off, no stutter. also when the ac is on i notive lag at really low rpm's like 1000RPM, when its off, smooth as butter. maybe its that.
06AspenWhiteSTi is offline   Reply With Quote
Old 08-11-2008, 05:32 AM   #12
Car: 08 STI
Uh, what? Why is cruise affecting it when I'm accelerating in second gear?
Old 08-11-2008, 05:43 AM   #13
Car: lexus ES350
Well, I would think others are thinking this so here goes.. I was under the impression these stage1/2 tunes were smoothing out the stock curves etc...
If thats the case what is going on here ?
ratedz is offline   Reply With Quote
Old 08-11-2008, 08:16 AM   #14
Car: STIzzle
Fav Mod: Tint
I have absolutely no stumble in any gear under any load with ac in any position. I have a stock 08.
Old 08-12-2008, 11:49 AM   #15
I too have a slight flat spot between between 2250-2750 on my stg 1.01 91 acn. Im also using 93 oct gas.
On a side note, during full throttle, looking at boost even in this low octane map I am still going a pound a half over target.
