Old 07-16-2008, 12:02 PM   #1
Car: 08 STI DGM
Fav Mod: Fiancé
Default How to remove realtime flash map?
Before I try to load up the valet map, how do I remove it other than resetting the ECU (which I don't even know which fuse is the correct one on my 08 STI)
FlashEngineer is offline   Reply With Quote
Old 07-16-2008, 12:12 PM   #2
Trader Rating: (14)
Default Re: How to remove realtime flash map?
disconnect battery
Old 07-16-2008, 12:53 PM   #3
Car: 08 STi
You can just do a realtime flash of the valet map, it will simply replace the map that is currently loaded as a realtime map. When done, just do another realtime flash of your normal map.
-Erik
Harman Motive is online now   Reply With Quote
Old 07-16-2008, 01:05 PM   #4
Car: 08 STI DGM
Fav Mod: Fiancé
Hmm but won't that have a "crappier" realtime map of my regular map? BTW do you know which fuse is for the ECU on the 08's?
Old 07-16-2008, 01:22 PM   #5
Fav Mod: Britax Roundabout
Ironic FlashEngineer should have this question but I digress....
With the valet map, you simply realtime it over your existing base (flashed) map and you'll be good to go. Then when you want your regular map back, simply real-time that map over the valet. You will get all the benefits of this map since you have the same flashed already. Hope this helps.
GilMikalian is online now   Reply With Quote
Old 07-16-2008, 01:30 PM   #6
Car: 08 STI DGM
Fav Mod: Fiancé
Lol the name has nothing to do with what I know or work, I just picked it since I couldn't really think of anything.. I'm actually a Software Engineer in Test Development/QA, but yeah that makes sense... I still would like to know which fuse is for the ECU so I can reset it from time to time lol.. Where is Fiend, I'm sure he knows but he never answers my PMs
Old 07-16-2008, 02:08 PM   #7
Car: 08 WRB STi
Fav Mod: ditching the cats
Go to the "Reset ECU" menu in your AP just like if you were going to clear CEL's. Hit ok to reset and it will clear out your real time map but it will keep your base map in place. It only takes a couple of seconds. The only way to clear out your base map it to reflash over it with another map. Disconnecting the battery or resetting the ECU won't clear out your base map, just real time maps.
Old 07-16-2008, 03:24 PM   #8
Car: 08 STI DGM
Fav Mod: Fiancé
Still don't know how to reset the ecu via fuse lol, do you know how? But thanks for this clearing of the realtime map though
Old 07-16-2008, 07:39 PM   #9
Car: 08 WRB STi
I believe If you reset the ECU by usuing the AP, it is the same thing as pulling the fuse.
