Old 07-14-2008, 06:57 AM   #1
Car: 06 STI
Default Power steering fluid question?
Owners manual recommends “Dexron III” Type Automatic Transmission
Fluid.
I need to top up my fluid but I am confused as to why it says ATF fluid?
Thanks for any help. Hope I am in the correct section.
06naSTI is offline   Reply With Quote
Old 07-14-2008, 07:14 AM   #2
If in doubt, flat out
Trader Rating: (23)
Default Re: Power steering fluid question?
That is correct. Use Dexron III ATF. It is red. Do NOT use power steering fluid.
Old 07-14-2008, 09:12 AM   #3
What about redline power steering fluid
itr_1211 is offline   Reply With Quote
Old 07-14-2008, 10:06 AM   #4
Car: 06 STI
I have seen a few people on here using red line. i guess this is why my question came up.
i'll stick to the manual for now.
Old 07-15-2008, 05:31 AM   #5
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Why do you need to add PS fluid? You shouldn't unless there is a leak or the factory messed up.
Old 10-02-2008, 02:41 PM   #6
Car: Black 06 WRX STi
Fav Mod: Cobb Lightweight Pulley
Send a message via AIM to Robpacific
I got some air in the lines and now my fluid keeps boiling as soon as I turn the car on. There are no leaks. What could be causing the fluid to boil immediately?
Robpacific is offline   Reply With Quote
Old 10-02-2008, 03:52 PM   #7
Trader Rating: (23)
you flash boil your fluid as soon as you start the car?
what are the symptoms/signs that make you think it's boiling?
Old 10-02-2008, 03:53 PM   #8
Trader Rating: (53)
there is no way the fluid is boiling immediately. How did you get air in the system? We have some motul ATF that has a higher boiling point than regular ATF. Should work well if boiling is actually your problem.
Old 10-02-2008, 05:08 PM   #9
let me restate: I keep getting air in the lines no matter how many times we work the bubbles out once we start the engine the air comes back. and the fluidkeeps boiling over if we drive it -- net result smoke under the hood. We put in a turbo inlet, tmic, tgv deletes, and walbro fuel pump. Any ideas?
Old 10-03-2008, 05:21 AM   #10
Trader Rating: (53)
Is your PS pump making noise?
Old 10-03-2008, 09:34 AM   #11
Trader Rating: (23)
blown ps pump is where my money is.
Old 10-03-2008, 10:06 AM   #12
Yes the PS pump is making noise with engine revs... louder if I'm turning the wheel. At first we figured that was just air in the line.
Here is my theory:
- When they redid the inlet they let air in the line.
- They should have cleared the air before they dynotuned it.
- They ran the engine hard, which ran the pump hard with air in it and that broke/cracked the pump which is now pumping air in.
If I just start the engine and do nothing else, it start bubbling which says PS Pump to me (also no leaks).
I took the car back to Subaru this morning. We will see what they have to say. JDM is $400+. Ouch. I don't suppose anybody makes an aftermarket PS pump I should look into while I'm at it... HA.
Old 10-04-2008, 10:10 PM   #13
Car: OBP 07 WRX
Try tightening or installing new clamps on the suction hose leading to the pump. It could be sucking in air causing both all those pump noises and the bubbling in the reservior as it returns.
omegax is offline   Reply With Quote
