Old 07-08-2008, 08:17 PM   #1
Car: Blue 08 WRX STi
Fav Mod: ProTune from Jorge at P&L
IWSTI Addict since: May 2008
Default OBD-II Port Question
Is The OBD-II port on an 08 STi a 16 pin? with pins on 4-5-7-16?
Thanks
BlueSubaru is offline   Reply With Quote
Old 07-08-2008, 08:20 PM   #2
Car: CGM 05
Fav Mod: IAG 38mm EWG
IWSTI Addict since: Mar 2008
Send a message via AIM to 1loudsti
Default Re: OBD-II Port Question
OBD-II connectors are all the same.....OBD-II is a federal mandate...the plugs gotta be the same
1loudsti is online now   Reply With Quote
Old 07-08-2008, 08:40 PM   #3
According to the tuner im talking to there can be different pin layouts(hes from NZ)I want to make sure the stuff he has is compatible before I order the stuff.
Old 07-08-2008, 08:42 PM   #4
Car: CGM 05
USDM OBD-II plugs are the same i know that...if they are pinned out differently in other countries that i cant answer
Old 07-09-2008, 05:33 AM   #5
Car: DGM 08 STI
IWSTI Addict since: Feb 2008
odb2 with CAN scan has a extra pin. older ODB2 doesn't have CAN scan network. but still the plug is the same.
TarmacST1 is offline   Reply With Quote
Old 07-09-2008, 12:17 PM   #6
OK Thanks guys
