Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Braking
Old 07-11-2008, 09:35 AM   #16
Fav Mod: hammer down!
IWSTI Addict since: Jun 2008
Default Re: STI 08 Brakes
Originally Posted by mattjk View Post
those methods have worked every since cars were made.
basic rule is to stiffen up the end of the car you want less traction.
Perhaps I was making it overly complicated. As mattjk pointed out, these are well known methods. There's a lot of suspension threads over on Nasioc explaining this stuff. The point that I was making was that with the multilink design of the '08's, stiffening the rear bar only reduced rear traction so much. I guess I should have said, "after which a stiffer bar has minimal negative affect on rear traction". A little surprising, so again I'll take this with a grain of salt until I've experienced it myself or seen mroe data.
Frank
