Old 07-03-2008, 04:20 PM   #1
Car: 2008 Sti
Default Cobb sent me the wrong AP but it works after Firmware upgrade
Gees... why cant they send the right part..lol
Guys let me know if I should return the AP or not..
So I recieved the AP last night, downloaded the ACN91 file, connect the ap to my car... AP shows the type of car after reading the ecu which is correct 2008 sti.. but when I click continue it wont go any further.. looking at the model on the actual AP it shows 2002-2005 ...
So did some research that firmware upgrade will fix the issue.. I flash the firmware on the AP with the current one AP-SUB-003.. at first the AP was looking for Access Port Manager\AP-SUB-001 subdirectory.. so what I did was rename the directory to AP-SUB-001.. then the firmware update worked.. and I was able to flash the ECU with ACN91V.101..
Should I revert back to stock and return the AP to cobb? should I be worried? I noticed on Sport mode there's hesitation on 3rd gear.. it;s fine on S#....
I guess I will restore the stock file and send the AP back to be safe what you guys think?
alex911s is offline   Reply With Quote
Old 07-03-2008, 05:07 PM   #2
Fav Mod: Britax Roundabout
Default Re: Cobb sent me the wrong AP but it works after Firmware upgrade
I would contact Cobb and go from there. Maybe you did all that's necessary. As for the hesitation, I know there is a learning curve for the ECU so you may just have to give a chance to adjust to the new maps.
Old 07-03-2008, 05:17 PM   #3
Car: 07 OBP STi
Fav Mod: Lead Foot
Uh,
Im pretty sure the only difference on the AP btw model years is the software. Contact Cobb, but the actual unit you have will be physically identical to the one used for 05-07, just different maps for the 08.
Grynchmeister is offline   Reply With Quote
Old 07-03-2008, 07:32 PM   #4
Car: OBP 08 STI/NAV/BBS
Originally Posted by alex911s View Post
So I recieved the AP last night, downloaded the ACN91 file, connect the ap to my car... AP shows the type of car after reading the ecu which is correct 3008 sti.. but when I click continue it wont go any further.. looking at the model on the actual AP it shows 2002-2005 ...
wow what kinda power do cars of that year make? does it fly too with hoverwheels?
Savarak is offline   Reply With Quote
Old 07-03-2008, 07:39 PM   #5
Car: DGM 2008 STI
Fav Mod: 292 WHP!! 352 TQ!! RaWr
You just have to update the manager software....
