Old 06-30-2008, 06:59 PM   #1
Fav Mod: Fuel
Default SPT Front Strut Tower Bar - 2008 STI
Just installed this. I have not seen one of the SPT versions posted yet. I got it from Subarugenuineparts last week -- I think it's only been available a month or so. It's all powdercoated gray and I cannot tell if steel or aluminum. SPT claimed it is aluminum center bar with steel rings on top of the strut towers. Didn't weigh too much.
Super easy install.
Torque for front strut tower fasteners is 14.5 ft-pounds. Torque for bar bolts is 35 ft-pounds. Sorry for the night time photo - but I'm sure you've seen these before.
It clears almost everything....it does rub against this hose that goes to the brake booster. Looks like I'll also have to remove it to access the brake or clutch fluid reservoirs.
Does anyone have any thoughts about this? Does this hose flex a lot while driving? It looks like it connects the intake manifold to the brake booster - is this a vacuum line to the booster?
It rubs this wire cover (to the wiper motor?). I doubt this flexes at all while driving and am not concerned here.
Given the strength of unibody construction I've thought of these more as engine compartment bling then anything real significant in the steering department. That being said, I took for a quick test drive after install. I <<think>> that there might be a hair less understeer. Could I be hallucinating?
Slimey is offline   Reply With Quote
Old 06-30-2008, 08:15 PM   #2
Send a message via MSN to RFFG
Default Re: SPT Front Strut Tower Bar - 2008 STI
Looks good
RFFG is offline   Reply With Quote
Old 06-30-2008, 08:20 PM   #3
Banned
Fav Mod: brown chicken brown cow
any strut bar that ties together a macpherson strut has to help somewhat. some cars more than others.
strut bars that tie together double wishbone with a subframe? purely bling.
mattjk is offline   Reply With Quote
Old 06-30-2008, 08:24 PM   #4
Car: 2008 Sti
Great job I love it.. I'll check the site
alex911s is offline   Reply With Quote
Old 07-01-2008, 11:12 AM   #5
Fav Mod: cylinder #4...
that brace looks really good! do you mind me asking how much it was? i have the cusco brace and i really couldn't tell a difference after it was installed. i think i felt the steering to be tighter? but i too could be hallucinating! as mattjk said, its pure bling. btw, i doubt those hoses will pose any problems. but you might want to protect the area that touching the brace in case it wears the hose down with time.
Old 07-01-2008, 04:37 PM   #6
Fav Mod: Fuel
$182.35 + shipping from SubaruGenuineParts
Old 07-01-2008, 06:45 PM   #7
Car: 08 Gray STi
Did the Cusco strut bars and the best test was a sweeper on the way to work that has a set of street-level rr tracks right at the apex of the curve. Hitting them "at speed" results in the car having a much flatter reaction (stays on track with no side stepping or body roll) than without the struts.
It's a more nuanced change than beefier anti-sway bars would be, but there is a difference.
2008 Subaru WRX STi - Cusco Front Strut Brace Installation
looks like there's more clearance of the fluid reserviours than on the SPT design.
Old 07-01-2008, 07:36 PM   #8
Fav Mod: Fuel
Default Comparison of SPT and Cusco Strut Tower Bars
Interesting - from the pics, the Cusco is set above the rear plastic flange on the engine compartment, and SPT is placed just below it.
Just putting the pics together for future reference.
hmmm...SPT is aluminum & steel & $182 (SubaruGenuineParts)
and the Cusco OS is aluminum & steel & $160 (RallySportDirect)
Old 07-02-2008, 07:27 PM   #9
Fav Mod: Fuel
Picked up some plastic electrical conduit (~$2 for 7 feet) from Home Despot on the way home today. Trimmed about a two inch length and partially covered the hose to the booster to keep from rubbing. Secured with zip tie.
Our engine compartment really gets hot. The strut tower bar was quite hot to touch (guessing ~120º - 130ºF) just from the home commute.
