Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Suspension, Handling, Stiffening
Old 09-09-2008, 03:25 PM   #46
Fav Mod: in transit
IWSTI Addict since: Dec 2006
Default Re: Rear Endlinks??
Originally Posted by Turninconcepts.com View Post
And just as a follow up - it's going to be a while. Kartboy went into the hospital last wed with chest pain, and actually ended up getting a quad bypass on Friday. He's in the hospital until at least the end of this week, and then he's not allowed to do ANYTHING for 4-6 weeks (no driving, no working, no running the milll...).
-Clint
hope he gets well soon... thanks
impressive is offline   Reply With Quote
Old 09-29-2008, 10:39 AM   #47
Car: 08 AW WRX STI
IWSTI Addict since: May 2008
Anyone tried the rear endlinks from Rallitek? Pricepoint isn't bad either.
RalliTEK HD Rear Endlinks 08+ Impreza WRX STi
GTI2STI is offline   Reply With Quote
Old 09-29-2008, 10:42 AM   #48
Fav Mod: hammer down!
IWSTI Addict since: Jun 2008
Perrin rear endlinks are now on the market. Anyone try them yet? They look good in principle- thinking about ordering them:
Old 09-29-2008, 10:46 AM   #49
Car: 08 AW WRX STI
^^^Nice. I'm interested in these also.
Old 09-29-2008, 12:01 PM   #50
Car: White 08 STI
IWSTI Addict since: Jan 2008
now what happens if you hit a large pothole or bump? if the stiffer rear bar reacts, causing a higher spring rate.
either the stock endlink will bend and save some suspension parts or wheels.
or a strong aftermarket endlink will not bend, but will the wheel bend or other suspension parts break?
hmm.. strong endlink or bend the stocker and save the wheels/suspension?
Rocket Rally Racing uses stock endlinks on their 08 Subaru Canada STI with bigger sways. Its cheaper to replace a simple endlink than a bent wheel or other suspension goodies. As i live in a pot hole haven, ill stick with the stock endlinks.
talsnic is offline   Reply With Quote
Old 09-29-2008, 12:18 PM   #51
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Do they have spacers for both sides of the rod end or just one on one side?
Old 09-29-2008, 12:40 PM   #52
there's more pics on their website- I think there's another spacer at the lower arm end, but not sure about the bar end end.
Old 09-29-2008, 12:48 PM   #53
Car: Silver 08 STI
IWSTI Addict since: Dec 2007
These look really nice. Are they rose-jointed like the stock pieces? My tuner tried the new Whiteline rear links when my Cobb sways were installed but he wasn't happy with their operation so I'm on the stock rear links still.
DrPhyzx is online now   Reply With Quote
Old 09-29-2008, 01:08 PM   #54
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
IWSTI Addict since: Feb 2008
What's wrong with the Whiteline endlinks? Can you be more specific?
Edvig is offline   Reply With Quote
Old 09-29-2008, 01:10 PM   #55
Car: Silver 08 STI
I wish I could, but I didn't see them fitted. If I had time, I'd still do my own work, but those days are gone...
Old 09-29-2008, 01:35 PM   #56
Car: 08 AW WRX STI
I think it has to do with the spacers supplied being slightly too large for the mounting point. Thought I saw someone mention they had to file them down to fit.
Old 09-29-2008, 01:37 PM   #57
Car: 08 STI
IWSTI Addict since: Aug 2004
6 months with Group A rears on my car, no issues
kris is offline   Reply With Quote
Old 09-29-2008, 06:36 PM   #58
Trader Rating: (53)
The spacers on the Whiteline endlinks are NOT too large. We have spoken with quite a few people on this recently after some rumors popped up that they don't fit. Fact is they are meant to fit tightly for performance and to reduce noise. I will be doing a write up tomorrow with pictures to help demonstrate the proper way to install them so that people will understand how they are supposed to fit. To date we have sold many sets and have only had one person complain that they could not get them install. They are a tight fit, but I wouldn't have it any other way.
Tony
Old 09-29-2008, 06:42 PM   #59
^^^not surprised to hear this. That folded piece of sheetmetal subaru calls a lower control arm is crimped slightly at the top so the opening is narrower than where the endlink mounting position is. It would be easy to think there's something wrong, but its just the way subaru designed the piece of metal. There seems to be a little more room if you move inboard towards the bottom of the shock a bit.
Frank
Old 09-29-2008, 06:51 PM   #60
Trader Rating: (53)
And if you loosen the lower shock bolt ont he control arm you get a little bit of play in the control arm. It will spread just a little making the spacer install a little easier. I get one spacer in, then the lower rod end. Then I start the other spacer just a little. Tap it a couple times with a hammer and it will be down in position. Tap the stock bolt through and you're set. This will all be in my write up tomorrow.
Tony
