Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Interior
Old 06-26-2008, 03:09 AM   #1
Car: Red 08 WRX Sti
Fav Mod: N14 Impreza
IWSTI Addict since: Jun 2008
Default Immobiliser - WRX STI 2008
How do I turn off completely the Immobilser ?
My car won't start and it has no fault codes......... turns over well...... but doesn't fire up ????
I am thinking its the immobiliser ?
Any help greatly appreciated.
Regards
redsti is offline   Reply With Quote
Old 06-26-2008, 04:37 AM   #2
Friendly Lurker
Car: 08 STI
Fav Mod: RCE Camber Plates
IWSTI Addict since: Mar 2008
Default Re: Immobiliser - WRX STI 2008
This may sound dumb, but did you try hitting unlock on your key thingy (sorry I just woke up)
Old 06-26-2008, 04:54 AM   #3
Car: Red 08 WRX Sti
Yep..... tried everything.....
I really would like to disable to whole thing.
Thanks
Old 06-26-2008, 05:07 AM   #4
Friendly Lurker
Car: 08 STI
Have you tried disconnecting the battery to reset everything? What makes you think it is the immobilizer?
Old 06-26-2008, 05:25 AM   #5
Car: Red 08 WRX Sti
Yep ... done that....
Scanned the fault codes and all ok.
So maybe the immobiliser is stopping it firing up ?
Thanks
Old 06-26-2008, 05:29 AM   #6
Friendly Lurker
Car: 08 STI
Thanks
I'm not really sure how the immobilizer is supposed to work, but the fact that the starter is cranking makes me think it is something else. Now I am curious...*sigh* there goes my workday
Old 06-26-2008, 05:32 AM   #7
Friendly Lurker
Car: 08 STI
Just found this if you are in a hurry and are sure it is the immobilizer:
https://subaru.locksmithsdrm.com/sr-sdrm/
Old 06-26-2008, 05:37 AM   #8
Friendly Lurker
Car: 08 STI
Also, did you try using your backup key?...sorry I'm just saying everything that comes to mind.
Old 06-26-2008, 05:56 AM   #9
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
IWSTI Addict since: Nov 2007
+1 on 2nd key
Wales Garage is offline   Reply With Quote
Old 06-26-2008, 05:58 AM   #10
Car: Grey 07 Sti Ltd
Fav Mod: Aerodynamic Dents
Send a message via ICQ to LTD472
I know you want to disable it but is it even connected? The immobilizer is suppose to keep the car from getting started so it won't get stolen. The way it works is it sends a signal to the key that has a computer chip, if there's a match, the car will start and stay on. If the car starts and the signals don't match, the car will start but it will not stay on. Also is your key the same one you got with the car or is it a new cut key? If it's new, the dealer will have to reset all the keys to the immobilizer. If you broke the immobilizer, well, you need a replacement and get it recoded. Hope this helps.
LTD472 is offline   Reply With Quote
Old 06-26-2008, 06:02 AM   #11
Car: '05 CGM
Fav Mod: HPDEs
IWSTI Addict since: May 2006
I agree....try your backup key.
It's possible that the immobilizer chip in your current key has been damaged. Trying your backup key will at least eliminate that possibility.
Have you done anything recently to the car (stereo install, mechanical upgrades, etc.)?
Gary
Old 06-26-2008, 06:07 AM   #12
Fav Mod: Car Comfort Design
IWSTI Addict since: Feb 2007
Ok. Might be silly but seeing as you may have tried everything Ill suggest something that I think you may have not tried.
Most of the new cars now a days that have a drive by wire throttle system have a certain feature that allows the engine to turn over but wont let it start, incases where you just need to circulate the oil and lube everything up before you need it to start. This feature is activated by holding down the throttle to the floor and turning the key.
So... What Im getting at is Maybe your floor mat is jammed on your throttle and holding it down to the floor.
If thats not it. Then try standing in the rain and screaming. "I COMMAND YOU TO START"
That should definately work.
JZeezSTi is offline   Reply With Quote
Old 06-26-2008, 07:04 AM   #13
Car: 06 Galaxy Gray RX-8
IWSTI Addict since: Apr 2006
Send a message via AIM to scubynewbie
Funny story, sorry it's a bit OT...My STi wouldn't start one day for god knows what reason and it was raining that day. It was sitting out in my driveway so I wasn't out anywhere. I got a little frustrated and yelled "WILL YOU START? LIKE TODAY??"...and she fired up.
scubynewbie is offline   Reply With Quote
Old 06-26-2008, 07:08 AM   #14
Car: 08 WRB STi
Fav Mod: Stage 1
IWSTI Addict since: Feb 2008
i was told that an excessive amount of keys/metal tags/etc. on a key ring can possibly interfere with the transmission ogf the handshake signal between the chip in the key and the receiver.
BuzSTid is offline   Reply With Quote
Old 06-26-2008, 07:23 AM   #15
I think who ever said that might be mentally retarded.. lol... j/k. I highly doubt it.
