IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi GR Series Discussion (2008+) > Technical
Old 06-23-2008, 11:06 AM   #1
Car: 04 STI
Fav Mod: Team Dosojin FTW
Default HHEELLPP!!alarm, interior lights, clock, radio do not work.
I know im retarded just help me out! first i checked the fuses and their fine. I was working on the wiring under the steering column and i forgot to disconnect the battery and a wire touched some metal and sparked and now the alarm, interior lights, clock, radio do not work. can someone help me identify the problem.
versus1ss is offline   Reply With Quote
Old 06-23-2008, 11:08 AM   #2
Car: 08white sti gold bbs
Fav Mod: emblem delete
Default Re: HHEELLPP!!alarm, interior lights, clock, radio do not work.
relay?
sleepsindirt is offline   Reply With Quote
Old 06-23-2008, 11:09 AM   #3
Car: 04 STI
do i have to take off the dash to reach it
Old 06-23-2008, 12:20 PM   #4
Car: 08 WRB STi
Fav Mod: ditching the cats
Sometimes fuses can be blown and not look blown. You should use a multimeter and test the continuity of the fuses. It might be worth a shot.
Old 06-23-2008, 12:38 PM   #5
Car: 08 Subaru WRX STI
Send a message via AIM to RAE129
You grounded out the circuit and burnt the fuse link. Check with a multimeter, like onlytakes4 stated or buy the little test lamp at autozone.
RAE129 is offline   Reply With Quote
Old 06-23-2008, 01:13 PM   #6
Car: 04 STI
i have a multimeter. so once i find out the problem how do i re-ground it.
Old 06-23-2008, 01:15 PM   #7
Car: '05 CGM
Fav Mod: HPDEs
You'll just need to replace the blown fuse with a good fuse.
Gary
Old 06-23-2008, 02:34 PM   #8
Car: 08 WRB STi
You shouldn't need to reground anything. Just take your meter find a good chassis ground and follow the wiring all the way back the best you can till you find where the power stops (faulty fuse, relay, etc.) and replace.
Old 06-23-2008, 04:01 PM   #9
Take the multimeter and place it on the continuity setting. When you touch the leads together it should make a sound, verifying you have continuity. The sound you hear is verifying that the circuit is continous (i.e. it is not open...a complete circuit from source to load). Go into your fuse box and check the fuses associated with the lights, radio, clock, etc. Place the hot and ground leads on either side of the fuse (looking at the fuse you should have two exposed conductive portions on either end of the fuse).
The conductors/cables/wires will not burn with a short to ground (aka your chasis) because they are capable of withstanding a larger amount of fault current.
Let us know how you make out.
Old 06-24-2008, 06:46 AM   #10
Car: 04 STI
problem fixed thanks for the help guys
Old 06-24-2008, 12:38 PM   #11
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Generally, as a courtesy to those that helped you out and for future reference for other members, you should always say what and how you fixed the problem. Just a suggestion...
Old 08-25-2008, 07:07 PM   #12
Car: 2002 wrx
HOW DID YOU FIX YOUR PROBLEM. I HAVE THE SAME PROBLEM ON MY CAR AND IT STARTED THE SAME WAY. PLEASE EMAIL dowhite215@hotmail.com
dougwhite is offline   Reply With Quote
Old 09-18-2008, 04:40 PM   #13
Does anyone know which fuse is related to the interior lights. Is it #16 in the cabin fuse panel? My interior lights are not working too...
MrDan is offline   Reply With Quote
Old 09-21-2008, 01:04 AM   #14
Hey probably went to the DEALER...!
-Garrett
Garrett is offline   Reply With Quote
