Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-I.C.E/Security
Old 06-19-2008, 07:31 AM   #1
Car: Silver 2008 WRX STI
Fav Mod: Rear Tints & Magnaflow.
IWSTI Addict since: May 2008
Question 2 Sub's in 08 STI
I was wondering if you can just splice together the wires of 2 OEM subs before going to the head unit ? Is it possible & did anyone tried it before (even on older OEM models)?
zoth is offline   Reply With Quote
Old 06-19-2008, 10:44 AM   #2
Car: 08 Gray STi
IWSTI Addict since: Jan 2008
Default Re: 2 Sub's in 08 STI
your impedance will drop if you do.
Old 06-19-2008, 11:02 AM   #3
Car: 2oo8 aw STi
IWSTI Addict since: Jul 2004
Tried it on my '05, it works, but it doesn't really make much difference vs having just one.
Old 06-19-2008, 01:17 PM   #4
Car: Silver 08 WRX STI
IWSTI Addict since: Apr 2008
Do the subs have their own power amps? If so, the impedance will remain the same, as there isn't any additional load on the power amps.
AudiAndy is offline   Reply With Quote
Old 06-19-2008, 06:18 PM   #5
That's what I believe in, and yes they are self-powered subs.
Old 06-19-2008, 06:20 PM   #6
Fav Mod: Britax Roundabout
My only concern would be are the amps receiving enough juice from the battery.
EDIT: What I meant to say is whether the subs are getting enough juice. I don't know how it's wired but using the stock wires, like it has been stated below is probably going to be the bottleneck in terms of getting enough power to the amps. I echo the other posts in suggesting an aftermarket solution since you will get WAY more for your money.
GilMikalian is online now   Reply With Quote
Old 06-19-2008, 06:20 PM   #7
Really...That sucks I thought it would sound a bit better. I would be happy to have a 30% to 40% improvement from one to two subs.
On what percentage would you rate the improvement from 1 to 2 subs.
Old 06-19-2008, 06:21 PM   #8
How about 1/2 Farad CAPS...
Old 06-19-2008, 06:27 PM   #9
Fav Mod: Custom Sound System
go aftermarket and get some real subs, the stock OEM sucks, and with two subs it'll suck twice as much. how about an infinity basslink? easy to remove when needed and much better than OEM.
calves is offline   Reply With Quote
Old 06-20-2008, 10:08 AM   #10
Oh, by the way would it be concern to have a 1 more sub total of pulling more power from the OEM radio harness ?
Old 06-20-2008, 02:38 PM   #11
As I understand it (and someone feel free to correct me if i'm wrong), the power for the subs aren't coming from the OEM radio harness, but from a power wire that is separate from the radio system. So whether or not that power wire can handle two subs depends on the gauge (thickness) of the wire. The only thing you're getting from the OEM radio harness is the signal, which can spread as many times as you want.
Again, run a separate power wire and go aftermarket.
Old 06-23-2008, 12:37 PM   #12
Thanks for the advise, with 2 kids & wifey and weedend travel every other week. A real sub-woofer system won't work for me. That's why I'm trying to make the best out of the OEM's.
Old 11-12-2008, 07:11 PM   #13
Car: white 06 STi
IWSTI Addict since: Jul 2008
definitley check out the basslink!!! very small, powerfull with the option of sliding in a 4 channel amp into the unit to power the rest of the speakers in the car. Its a all in one, light weight unit! I don't know why they are not more popular.
surfersti is offline   Reply With Quote
Old 11-12-2008, 09:17 PM   #14
Car: 08 aw sti
IWSTI Addict since: Jun 2008
All I am going to say is do not under any reason go with a "CAP". Just please trust a random guy like me when I say NOTHING good comes from them, there are alternative methods.
nbudros is offline   Reply With Quote
