Old 06-16-2008, 06:34 AM   #1
Car: 08 STI
Fav Mod: Removing the window sticker
Default First try starting issue after a flash?
Anyone else have a problem with starting the first time after reflashing with an AP? Whenever I do it, I shut the ignition off (per instructions), disconnect the AP and try to start it and it just turns over without a hint of being ready to start. It fires right up the second time. I've tried even turning the igntion on and then back off to simulate the first failed start, but it doesn't work. You have to actually crank the thing and then turn the ignition off before it will fire up on subsequent attempts.
tshrey is offline   Reply With Quote
Old 06-16-2008, 06:48 AM   #2
Car: Dark Grey 08 WRX STi
Fav Mod: Mud to the exterior
Default Re: First try starting issue after a flash?
Yep! It's normal. After you disconnect the AP and turn the key to off, instead of starting the car just turn the key to the ON position for about 10 seconds. Then just start 'er up!
shagnwrx is offline   Reply With Quote
Old 06-16-2008, 07:27 AM   #3
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Completely normal. It can take up to 5 seconds to start sometimes while other times it will start right up.
Digitalfiend is online now   Reply With Quote
Old 06-16-2008, 09:08 AM   #4
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
If you listen closely after you turn the car off after flashing you will hear a relay click. If you try to start it before that relay clicks, it will not start. If you wait till after it will start right up.
Old 06-16-2008, 09:44 AM   #5
Fav Mod: AP
I've read about this before I installed my AP but I still started my car right away Ofcourse it didn't start I was just too excited to do the test drive
luis3rd is offline   Reply With Quote
Old 06-17-2008, 03:22 PM   #6
Fav Mod: Volk RE30's and 255-35 Dunlop Z1's
I recall also that the electronic throttle needs a chance to cycle the intake butterfly or something along that line.
Maybe that's the relay noise??
ploney is offline   Reply With Quote
Old 06-17-2008, 03:24 PM   #7
Fav Mod: clearbra
yea I havn't had it with my AP but I was going to say when I had APR on my GTI it was common after flashsing
limited777 is offline   Reply With Quote
Old 06-20-2008, 02:49 PM   #8
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
I had it never start back up for me twice. Second time cobb dealer himself installed the ap and it burned the ecu the second time. Cobb took care of me with no problems and overnighted the ecu and ap tuner already installed.
