Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-I.C.E/Security
Old 06-03-2008, 01:06 PM   #1
IWSTI Addict since: Jun 2008
Default Plugging into OEM GPS Antenna.
In my 08 STI there are 2 cables coming out of the roof antenna. There is an unused plug from that harness behind the radio which seems to be the plug-in for the OEM GPS head unit. Does anyone know what kind of plug this is so that I can plug into it??? Many Thanks!
SubaruChas is offline   Reply With Quote
Old 06-06-2008, 03:20 PM   #2
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
IWSTI Addict since: Nov 2007
Default Re: Plugging into OEM GPS Antenna.
are you sure that isnt the plug for the xm/sirus option. i think the gps is off the radio antenna.
Wales Garage is offline   Reply With Quote
Old 06-07-2008, 06:48 AM   #3
I am not sureif it is for XM/Sirius or GPS. But, isn't a satellite antenna a satellite antenna?
Old 06-07-2008, 08:51 AM   #4
Fav Mod: 292whp/326wtq
IWSTI Addict since: May 2008
Usually, both the XM/Sirius and GPS feeds would come from the same, or similar antenna... the FM antenna is obviously the one that's sticking straight up...
It's it's an "unused" plus, and you DONT have satellite radio or nav, then you could be right!
Old 06-09-2008, 06:43 AM   #5
I really want to just plu into the factory plug rather than running a new line. Does anyone know anything about the plug on the end of the factory harness?
Old 06-09-2008, 05:07 PM   #6
Car: Silver 08 STI
IWSTI Addict since: Apr 2008
could you take a picture of it or a least decribe the plug ie color, etc
jrdriller is offline   Reply With Quote
Old 06-11-2008, 10:44 AM   #7
I found what it is. it is called a HRS GT5-1S coaxial connector. Now....where can I get one?????? I will have to do more research
Old 06-11-2008, 10:45 AM   #8
It is a HRS GT5-1S coaxial connector. I will have to see where we can get these!
Old 06-11-2008, 11:21 AM   #9
Car: Silver 08 STI
OK so it is either a GPS or XM/Sirius connection. You say that your car is not equipped with the navigation unit, so I would venture to guess that it is GPS and not XM/Sirius because the installation kit for those units includes an antena which you will find towards the bottom of this page
Free Publications > Accessory Installation Guides
Cheers
Old 06-11-2008, 06:11 PM   #10
Cheers
I just plugged into it! It is the integrated GPS ant. !
Old 06-11-2008, 11:57 PM   #11
Can you get a picture of the plug?
