| | #16 | |
| Junior STI Driver | Quote:
As far as grip..I would rather have a sticky -narrow- light tire, than a hard compound tire that's twice as heavy and twice as wide. Rolling resistance has as much to do with tread design, tire compound and weight. Probably more so than the dimensions of the tire. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #17 | |
| Amateur STI Driver | Quote:
I think we have all agreed on that. Wider yes. Larger contact patch no. So does it come down to wider tyres giving more grip because : The normally have lower profile and stiffer sidewall They normally tend to be higher end tyres with correspondingly better compounds And lastly (the question I am trying to ask) - Does contact patch width matter more then contact patch length? | |
| | #18 |
| Junior STI Driver Car: 2005 PSM STi Fav Mod: APS TBE Location: Savannah, GA Posts: 128
IWSTI Addict since: Apr 2007 Trader Rating: (1) | I think you meant a wider tire doesn't = more "contact patch". A wider tire does have more surface area as there is more matter for heat to be displaced. It doesn't matter if all of the rubber contacts the road, it still aids in at least some heat dissipation. |
| | #19 | |
| Professional STI Driver
Car: 05 WRB/Gold STi Fav Mod: Whiteline Sways Location: Northeast PA Posts: 487
IWSTI Addict since: Aug 2007 Trader Rating: (0) | Quote:
ex: 225/45-17 has the same sidewall as a 255/40-17 | |
| | #20 |
| Silver Member
Car: 2004 WRB STi Location: Atlanta,GA Posts: 2,090
IWSTI Addict since: Aug 2006 Trader Rating: (14) | |
| | #21 |
| Junior STI Driver Car: Silver 08 STI Fav Mod: Coming Soon Location: Houston Posts: 197
IWSTI Addict since: Apr 2008 Trader Rating: (0) | This ad is not endorsed by this member. Please register or login to hide this ad. |
