Old 06-04-2008, 07:55 AM   #16
Car: 08 STI
Fav Mod: Removing the window sticker
Default Re: Sub option without giving up cargo space
I'll take pics tonight. But yes, the false floor always stays in, otherwise what is the point? I wanted bass that you couldn't see and that would take up as little space as possible.
Because the speaker grill sits above the normal level of the false floor you have to make wedges that tilt the floor up in the back. I'm still working on that part - I currently have cut a couple out of foam as a temporary measure, but it's craft-type open cell styrofoam that is kind of crumbly and is making a mess back there. I haven't decided what I will ultimately use, possibly a much stronger foam or the really heavy-duty 1" thick cardboard. Most likely the foam because I have a hot-wire cutter that I could use to make the wedges.
tshrey is offline   Reply With Quote
Old 06-05-2008, 04:16 AM   #17
Car: 08 STI
Pics as requested. First is the fiberglassing process; since you can't see the bottom of the enclosure I didn't go through the effort of making it smooth. I just lined the spare with aluminum foil, sprayed a mold release on it and started laying in resin soaked strips of fiberglass mat.
Next, since you are using up the space that used to hold the jack, you have to modify the passenger side foam piece to hold the jack...
Enclosure with new 12" Kenwood in place and a couple of the wedges that have to be made to hold up the now-tilted false floor.
What it looks like with the floor in place.
Old 08-15-2008, 05:28 PM   #18
Car: 2007 STI OBP
Fav Mod: Coming
Great info! I'm thinking of getting out of my 07 with a 12" JL in a box and moving to a 08 but didn't want the box in view.
rkwdoc is offline   Reply With Quote
Old 08-19-2008, 09:38 AM   #19
Car: Red 2008 STi
Fav Mod: 1L Rockstar
Originally Posted by WRXGuyInUSA View Post
Sweet!
I'm hoping JL comes out with a stealthbox for the STI... *crosses fingers*
yeah me too i just have mine in the corner of the car so i cant take corners and full speed gotta slow down so it doesnt hit the other side of the car....
Red08onGOLD is offline   Reply With Quote
