Old 05-28-2008, 04:06 PM   #1
Default 2008 STi DRL disable???
After a long decision making process I pick up my 2008 Spark Silver/BBS STi tomorrow (Thursday)!!!
I was wondering if anyone has had any success in disabling their DRL's on an '08 STi??? I searched but couldn't really find what I was looking for as far as what to unplug or take apart.
Any help is greatly appreciated, I've learned a lot already by doing some lurking. Thanks!
KillerBlackBird is offline   Reply With Quote
Old 05-28-2008, 04:24 PM   #2
Car: Silver 08 STI
Default Re: 2008 STi DRL disable???
Should be easy enough, but seriously, I don't get why people do this...
DrPhyzx is offline   Reply With Quote
Old 05-28-2008, 04:32 PM   #3
Fav Mod: Hatchback!
Just did mine (S'poreSTI Redux - 08 WRB/Gold. JDM Gauges installed.)
Really simple, just take off the bumper and disconnect the cable from the resistor, the big silver thing in the pic below, then fasten the cable out of the way so it doesnt rattle around. done
S'poreSTI is offline   Reply With Quote
Old 05-28-2008, 04:33 PM   #4
Well, I should of asked this too; do the tail lights come on with the DRL's??? I have seen some cars driving around at night with DRL's activated but no tail-lights. I am the type of jackass that doesn't remember to turn on the headlamps when it gets dark so the tail lamps are illuminated and not just the DRL's. Also I don't mind prolonging the life of the expensive HID bulb not having them on when they don't need to be.
Old 05-28-2008, 04:34 PM   #5
Freakin' sweet!!! Thanks. Sounds like a good weekend project.
Old 05-28-2008, 04:37 PM   #6
Fav Mod: Hatchback!
Just the fronts, and its not the HID's, on the 08's the high beams are used, but at lower output when in DRL mode
Wait till you get the car, then decide if you like it or not. easy thing to change
Old 05-28-2008, 04:54 PM   #7
Car: Silver 08 STI
The HID's don't run for the DRLs. First clue that the lights aren't on is no instrument lights. Since I think that is a bigger clue than the impotent DRLs, you have to ask how many of those cars you see at night with DRLs only would have no lights on at all if they were disabled.
Old 05-31-2008, 08:44 AM   #8
Car: 08 STi, 08 Ram 1500
Fav Mod: Accessport
you dont need to take the front bumper off to do this.
just pull back the fender liner and unplug it.....takes like 5 minutes instead of a hour.
jb97gsx is offline   Reply With Quote
Old 05-31-2008, 12:09 PM   #9
After closer inspection I think I'm going to leave it the way it is, being that the DRL's are in the high beam and not turning the HID's on un-necessarily. I thought it was tied into the HID's. I can live with it.
Thanks for your help again!!!
...and this car is amazing. I cant wait until break in period is over.
Old 06-02-2008, 06:39 AM   #10
Car: Silver 2008 WRX STI
Fav Mod: Rear Tints & Magnaflow.
Do you do this on both sides or just the the passenger side ? Thanks in advance.
zoth is offline   Reply With Quote
Old 06-02-2008, 08:05 AM   #11
Car: OBP, 2008
Send a message via AIM to method
You can do it by just removing the 3 pop clips on the pass side fender and reaching in, you don't have to remove the whole bumper though it's probably easier to get to if you do.
method is offline   Reply With Quote
Old 06-03-2008, 09:55 AM   #12
Attached is what I have done to disable it. Much Easier way..
Old 06-03-2008, 12:05 PM   #13
Zor
Car: 08 DGM STi
just did it this way took about 30 seconds
Zor is offline   Reply With Quote
Old 06-03-2008, 12:07 PM   #14
Fav Mod: Owning it...
Send a message via AIM to deeksmooth Send a message via MSN to deeksmooth Send a message via Yahoo to deeksmooth
this effects all DRL's not just headlights right?
deeksmooth is offline   Reply With Quote
Old 06-03-2008, 12:12 PM   #15
Zor
Car: 08 DGM STi
correct, it just stops the DRL's from being on does not effect the headlights at all, I checked lol
