Old 07-24-2008, 05:23 AM   #16
Car: '08 WRX STI
Fav Mod: I don't know any of the mods on this forum.
Default Re: Invidia DP & exhaust for the 08 sti
Originally Posted by Jay Jr View Post
I've heard the N1 on an 08 WRX, sounded great. Yet, too wondered if it was available for the STi. Doesn't the factory CB flow great numbers to support just the Invidia DP? Like the cleanliness of stock appearance. . .
Yeah, hi rookie post
I've already decided the same thing. I'd prefer to stick with the stock exhaust on the STI and run Stage 2 than spend money on something louder, uglier, and only a few HP more.
yakkosmurf is offline   Reply With Quote
Old 07-25-2008, 12:14 PM   #17
Car: AW/Gold 08 STI stg2
Fav Mod: hands
uglier?......
OH8STI is offline   Reply With Quote
Old 08-01-2008, 04:29 PM   #18
Car: White 08 WRX STi
so i ended up getting the invidia catless DP just wonder if n e one know where i can find install procedure. any info would be good i tried searching but came up empty
thanks
flowsti is offline   Reply With Quote
Old 08-01-2008, 05:35 PM   #19
Trader Rating: (50)
Look in the how to install section. The install on the older models is exactly the same.
Old 08-01-2008, 08:38 PM   #20
Car: 08 sti stg 2
ill have the invidia cbe installed on mon with perrin equal lenght headers. Already had the dp from invidia with samco turbo inlet hose. im gettin the retune on tuesday. first tune posted on you tube. "08 sti stage2 prt 1" the second you tube post will be done wed ... word!!!
filthy is offline   Reply With Quote
Old 08-01-2008, 10:10 PM   #21
Banned
Fav Mod: brown chicken brown cow
thanks
here is a tip I can give you. do not let the engine cool down too much. if the fasteners get cold, wd40 or breakfree won't help you. you will most likely break a stud.
i've always removed exhaust fasteners with the engine mid-warm. never had a problem. tough to work on, but never had a problem.
my buddy with an 05sti, didn't listen to me. 800 miles on his car and he busted a dp stud and a stud off the uppipe. (replaced the turbo with a bigger unit). had to spend an additional 3 days removing the uppipe, taking it to a machine shop, have them extract the stud, and then re-install the uppipe.
he was cussing the entire time.
mattjk is offline   Reply With Quote
