Old 05-20-2008, 08:58 AM   #1
Car: Silver 08 STI
Default Question; anyone running Perrin's PSRS
Is anyone running Perrin's PRSR?
Perrin Performance - Positive Steering Response System
Looking for some feedback/comment
jrdriller is offline   Reply With Quote
Old 05-20-2008, 03:53 PM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Question; anyone running Perrin's PSRS
A few people are.
Old 05-20-2008, 04:43 PM   #3
Car: Silver 08 STI
thanks. any feedback/opinion v their performance
Old 05-21-2008, 08:22 PM   #4
Car: Black 08 STi
^^^Bump
SlackerNJ is offline   Reply With Quote
Old 05-23-2008, 11:03 AM   #5
Car: 02 Stg2+ WRX, 08 STi
Fav Mod: pink I badge
I had these on my 02 WRX (Vishnu Stage 3) and had some issues... they were very loud and clunky (but nice handling upgrade). I switched to Whitelines version and have liked them since. Same handling bennies but much quieter. Not sure if same dynamics on an 08 Sti. Curious as Ill be adding to new Sti one or the other at some point as well.
bschweig is offline   Reply With Quote
Old 05-23-2008, 06:21 PM   #6
Car: Silver 08 STI
Thanks for the feedback. have whiteline finsihed developing their 08 STI stuff? last time I checked their website I didn't see anthing for the 08 STI
cheers
Old 05-24-2008, 03:41 PM   #7
Car: LR 2008 WRX STI
Fav Mod: Bigger Turbo
I had these on my WRB STi and i did not care much for them. they would make a loud popping noise when i was turning real sharp, like parking or pulling into a driveway. But if i do go the suspension route and my car is going to be a daily driver, I would go with Whitelines PSRS with the urethane bushings. You need togive Tony or Clint a call @ TIC. They can steer You in the right direction. ( No Pun Intended ) LOL
Rotated is offline   Reply With Quote
Old 05-24-2008, 03:48 PM   #8
Car: Silver 08 STI
Thanks for the feedback. Sounds like Whiteline's the way to go. I'll check out TiC's web site to see how they are getting on with their new 08.
Again thanks
Cheers
Old 05-24-2008, 03:56 PM   #9
Car: 2004 "JCT" JBP STI
Fav Mod: 35r
I have perrin psrs, and it may make a few odd noises here and there but not enough to really bother me. The handling upgrade was quite immense though. The suspension upgrades on my car are probably its biggest asset besides the gt35r rotated, and the psrs certainly rounds it off. The car handles like a go kart, and essentially can turn as fast as you can hold on. I cannot stress how tight and grounded the car is, its amazing!
this is my suspension setup:
Tein Flex Coil-overs w/ EDFC
STI Strut Brace
Perrin PSRS
Perrin Cross Lock Sub-frame Brace
Perrin Sway-bar
Agency Power End-links
Agency Power Rear Control Arms
BigTrippin is offline   Reply With Quote
Old 05-25-2008, 02:46 PM   #10
Trader Rating: (53)
Whiteline has an ALK coming out for the 08 soon hopefully. I have seen install instructions for it and it looks very nice. Superpro also has a bushing kit out for it that was made for the late model LGT. It fits the same in the 08 and has the same caster gains as other kits.
These are both bushing types which are typically better for a daily driven car due to NVH.
Tony
Old 05-25-2008, 04:33 PM   #11
Car: Silver 08 STI
STI Strut Brace
Perrin PSRS
Perrin Sway-bar
Wow, sounds like a great set-up. much more than I'm looking for at this time. how do you like the EDFC?
cheers
Old 05-25-2008, 04:35 PM   #12
Car: Silver 08 STI
Tony
Thanks for the feedback. hopefully we'll see the parts starting to arrive soon.
cheers
john
Old 05-25-2008, 08:01 PM   #13
Fav Mod: 35r
The EDFC is cool cause you can actually feel the difference after you adjust it, but more cool because it makes noise as you adjust it so it sounds really impressive to everyone in the car. Apart from the incredible cool factor it actually has helped the car be more balanced and aggressive when I need it to be, so in many ways is worth it. I really got it because its obvious my setup is very aggressive so its good to be able to control just how much.
Old 05-25-2008, 08:38 PM   #14
Car: Silver 08 STI
It would be really neat if you could tie the controller into the car's SI Drive or DSC
anyway I'm going to take a more gradual approach ie start with bushings, see if that does it, ...
Old 05-25-2008, 08:52 PM   #15
Car: 03 WRX
Fav Mod: STi powertrain
i love the way my car handles, but when parking it is so annoying. get whiteline's
bradze is offline   Reply With Quote
