| Gold Member Car: Blue 08 STI Fav Mod: AMR stg 2 Location: Nothern, VA Posts: 141
IWSTI Addict since: Mar 2008 Trader Rating: (0) | Has anyone attempted to replace the 08 crank pulley yet? Apparantely the set up is defferent from previous years. I beleive there is a tentions bolt missing. Any light on this will be greatle appreciated. I have been reading about this replacement and was wondering, and i know there is a lot of heat on this, if there are pople out there that has replaced it witha dampered pulley vs. a LW pulley alone that might give me some info. Thanks in advance. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Authorized Vendor Fav Mod: Most Copied parts on IWSTI! Location: San Diego, CA Posts: 329
IWSTI Addict since: May 2004 Trader Rating: (4) | the guys at TIC have installed one of ours with good results. i havent had time to try the install on our shop STi yet. not sure if others will fit. T |
| | #3 |
| Junior STI Driver | The new setup does not have a tensioner at all, just a stretch belt. I saw a thread on 3gwrx about this. They cut the belt off and the new belt came with a tool to install a new stretch belt. I hope that there is a another way to do this. |
| | #4 |
| Authorized Vendor | I have replaced the crank pulley with one of kartboy's (Great pulley btw!!). It was pretty straight forward to work around the AC belt. I loosened the bolts that hold the AC compressor in place to get some slack on the belt. That allowed me to take a flat head screwdriver and work th ebelt off the pullet more easily. Same process only in reverse for getting the belt back on. I have had no issues with stretching of the belt and all is well some 5000 miles later. Tony |
| | #6 | |
IWSTI Addict since: Mar 2008 Trader Rating: (0) | Quote:
| | #7 |
| Junior STI Driver | To my understand light weight pulleys r very unhealthy for the motor. The reason why subaru's is heavy is becuase it is used to dampen the engines vibrations. OEM engines are balanced with this pulley. Putting on a leighter pulley may lead to faster wear and tear on ur bearings and other internal compenents. IMHO it is not worth it, but on the other hand their is no definitive evidence that proves pulleys cuz more wear and tear but it is a theory that many knowledgeable tuners and engine builders agree on. |
| | #8 | |
| | #9 |
| Grassroots STI Racer
Car: '08 STI, OBP Fav Mod: hammer down! Location: Gaithersburg, MD Posts: 569
IWSTI Addict since: Jun 2008 Trader Rating: (0) | There was a company releasing lightweight damped pulleys this winter - not sure if they've released one for subaru's yet. I'll have to go look for the article where I saw it. FWIW, I've had a lightweight pulley in my '02 since 20k miles. Its now over 70k running stage 2 with no problems. There's always tons of answers like this whenever these get brought up, but no one can ever point to engine X and say, "it just gave up for no reason, maybe it wore out because of the crank pulley," or, "my front crank bearing failed prematurely." I wish someone would though so we could assign a probability to it happening... Frank |
| | #10 | |
| Professional STI Driver Car: Silver 08 STI Fav Mod: Coming Soon Location: Santa Cruz Mountains Posts: 490
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Quote:
Perrin claims that this is equal to removing 100 lbs. of non-rotating mass, to which I call a giant B.S. That would imply that this part is 30 pounds lighter than the stock piece... and the advantage shrinks pretty quickly in the higher gears. Now... if the idea is quicker response when blipping the throttle... that can actually make sense. ... OK... so looking at Perrin's page, they claim 4 pounds lighter than stock. That's equal to 12 pounds of mass from anywhere else when in first gear. FAIL. Last edited by DrPhyzx; 06-30-2008 at 01:46 PM. Reason: Included Perrin's weight figures. | |
| | #11 |
IWSTI Addict since: Jun 2008 Trader Rating: (0) | |
| | #12 |
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Not sure if you're serious or not, but here is the version of the calc I did while enjoying the drive to work ![]() Again, assume mass is concentrated at about 2" radius, and that any material removed will be concentrated at that radius. (What we really want for this simple version of the calculation is the r^2-weighted mean, so mass near the outside dominates the calculation.) Now... how fast does that material move due to crank rotation at 6000 RPM: v = pi * d * 6000 = 3 * 1/3 ft * 6000 (1/min) = 6000 feet/min * (60 min/hr) / (5280 feet/mile) = 68 miles/hr So... at 6000 rpm, the effective mass of the pulley is moving at 68 miles per hour. In first gear, that is probably about twice as fast as the car is moving, so you've saved twice the mass reduction on any other part of the car just getting it spinning. Now, of course, you also have the linear motion of the pulley, where you've saved just like you would for any non-rotating part and there is your factor of three. So... saving 4 pounds off the pulley is like 12 from any non-rotating part of the car. Gotta run... |
| | #13 |
| Lurker | yea the ac compressor is a full on bolt on you are going to have to cut your ac belt in order to get the other pulley on. and you are going t spend about 80 dollars for a new a ac belt. this years belt is a stretch belt that you have to rotate into the actual pulley. |
| | #14 | |
| Junior STI Driver Car: 08 STI!!! Fav Mod: zero done yet Location: michigan, the getto troy Posts: 53
IWSTI Addict since: Jul 2006 Trader Rating: (0) | Quote:
dude one... ur ****ing smart as **** and two if this is bull**** or not id still believe it just because he put so much thought into it... i gotta give u a even tho i have no idea ever to see if ur math it right or wrong let me call me asian friends and ask them what they think lolol | |
| | #15 |
| Authorized Vendor | The big discussion of lightened pullies and removing the damping the stock one provides is the side loading of the front crank bearings. A very valid concern in inline engines for example. Thing is despite everyone screaming about this I have yet to see an example of a dead bearing due to side loads from removing the damper on a boxer motor. This ad is not endorsed by this member. Please register or login to hide this ad. |
