Old 05-16-2008, 10:39 AM   #1
Car: Silver 08 WRX STi
Fav Mod: Mud Flaps/CAI,DP,Pro Tune
Default 244 code w/ new Cobb Map 1.01
I got a 244 CEL this morning with the new COBB 1.01 map.
Digitalfiend,Please do not close this thread...Chris from Cobb is asking for feedback in the first one you closed.
Hard pull in 5th gear,4% grade, 7800ft. elevation.I know...not ideal for an OTS map.
The car felt like it had more power than with the 1.01 map...till I got the "pop" and the code.
Giant is offline   Reply With Quote
Old 05-16-2008, 12:40 PM   #2
Fav Mod: Britax Roundabout
Default Re: Reporting Back
Ugh, not so good news I only got the code once on my Stage 2 ACN map v1.00 aboud 2 weeks ago. I switched to the v1.01 map last night. Hope I don't get the code again. So far so good.
Giant, I think you may want to rename this thread so its more clear for all. Just a suggestion.
Old 05-16-2008, 03:16 PM   #3
Thanks,Good idea.
Old 05-16-2008, 04:26 PM   #4
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Default Re: 244 code w/ new Cobb Map 1.01
I wasn't planning on closing this one. I didn't see any request for feedback from Christian in that other thread...just a pointer to the update (from another user), which is why I closed it.
This thread has a purpose.
The car felt like it had more power than with the 1.00 map...till I got the "pop" and the code.
Are you able to do any datalogging for us?
I've added an update to the sticky telling people that still have the problem to post here.
Old 05-17-2008, 05:30 AM   #5
Car: OBP 08 STI
Fav Mod: AccessPort
Cobb ver 1.01 maps released
Giant in the other thread that is now closed you said you did a realtime flash which I thought was the incorrect thing to do, you are supposed to do a reflash. Could that be your problem?
sleepyhead is offline   Reply With Quote
Old 05-17-2008, 06:20 PM   #6
Fav Mod: Advan RS 18x9. TurboXS downpipe.
Ouch, yeah
you shouldve done a full reflash, not real time.
paikman is offline   Reply With Quote
Old 05-17-2008, 08:37 PM   #7
I did a realtime OVER the reflash.
Old 05-17-2008, 09:13 PM   #8
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
A realtime over the 1.00 map or you installed 1.01 then did the real-time on top of that? If you only "updated" by installing the real-time map, that is probably why it didn't work that well for you. The base map has additional tables, etc, that the real-time maps don't. Just a thought.
Old 05-19-2008, 09:07 AM   #9
Car: 08 WRB STi
Fav Mod: ditching the cats
i have a catless DP and would get an overboost code everytime at WOT in 4th gear on the v1.00 map. I did a reflash of the v1.01 map this weekend and it doesn't hit an overboost code now in any high gear at WOT (even 6th). But, it does feel like it isn't as much power as the v1.00 map.
Old 05-19-2008, 09:14 AM   #10
I did a realtime 1.01 over the1.01 reflash.I'm 100% I did it correct, that's why the code is freekin me out!!!!!!
Old 05-19-2008, 09:28 AM   #11
jph
how long after flashing the new map did you get the code?
when i initially flashed a new map on my '04. i'd overboost a few times during the first week.
after that, the ECU learned enough to compensate for all of this, and it never happened again.
just a thought
J.
Old 05-19-2008, 11:10 AM   #12
just a thought
J.
Good thought JPH!!!...It had only been a couple of hours,and 45 miles since the 1.01 reflash,when I got the code.Thanks,JPH that could be it.I'll drive it around a couple more days,and do another pull under the same conditions,and report back.
Old 05-19-2008, 01:46 PM   #13
Car: Silver 08 STI
i reflashed to 1.01 (93) then followed (as always after an ecu reset) the old "Vishnu" ECU/Ignition Advance Multiplier technique which you can find at this link. Re-Mapped ECU Learning Trick 10-20hp in 5 seconds - NASIOC which seems to work for me. I have noticed a bit of very low end "hesitation" compared to the factory map, and this was also a complaint by some with 1.00 map
cheers
jrdriller is offline   Reply With Quote
Old 05-20-2008, 08:35 AM   #14
i threw 0244 three times on the 1.00 stg 2 catted DP map and just wandered in the other day after about a month of being away and saw the updates for 1.01. reflashed this past saturday night (05/17) and the car is stronger than ever now. throttle response is improved and the jerkiness and hesitation between 2-3K rpm is all but gone.
btw, i performed a full reflash of the 1.01 map for those keeping score.
droideka is offline   Reply With Quote
Old 05-22-2008, 08:14 AM   #15
Got the code 2 times yesterday while hooked to romraider,the only weird thing my buddy saw was...Fuel pump at 100%,injectors only at 77% of max...I don't know much about this stuff,but that is what I was told.remember I'm getting the code at 7600ft. elevation.
