Closed Thread
Old 05-15-2008, 01:57 PM   #1
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Default CobbTuning 2008 STI AccessPort Map Update 1.01 (Fix for boost creep issues)
CobbTuning has updated the maps for the 2008 STI to address the overboost issue some have experienced here. Please post any comments regarding this map in that thread.
If you are still experiencing boost creep with these update maps, please post in this thread.
Originally Posted by Chris @ COBB View Post
We have released a 1.01 revision to all the 2008 STi maps.
2008 STi Maps
1.01 - Revised Boost Limits parameters, modified WGDC tables to avoid boost creep in higher gears, and increased authority for the boost control system to make corrective adjustments.
To use any map off of our website you need to make sure you are using the most recent version of AccessPORT Manager and you need to have firmware 1.2.X.X or higher on your AccessPORT. You can check your firmware in the About menu on the AccessPORT. If you have older firmware, here is a link to the most recent firmware:
Firmware 1.2.6.X
Those of you that are having over boost issues, try the new 1.01 map and report back with how the car is performing.
Digitalfiend is offline
Closed Thread
