Old 05-14-2008, 11:48 AM   #16
Fav Mod: Cobb AP
Default Re: best suspension for 08
Just get some sways and a good alignment and you're set for autoX.
But I heard that aftermarket front sways are too short, making the endlinks connect at an extreme angle. Any takes on this?
inpuressa is offline   Reply With Quote
Old 05-14-2008, 11:50 AM   #17
Fav Mod: Autotrader.com
Nobody makes an aftermarket front sway yet except Harman and their prototypes look just like the stock bar, which is also a bit too short looking. The WRX bars are WAY too short.
Old 05-14-2008, 07:58 PM   #18
BC Racing has a very affordable coilover solution out for the 08's now. Go check them out Darkside Engineering
Evo-L is offline   Reply With Quote
Old 05-15-2008, 04:37 PM   #19
Fav Mod: Cobb AP
cusco seems to have bars available.
新インプレッサ用 スタビライザー 新発売 新製品情* 製品情* クスコウェブサイト
but if you look closely, the endlinks are at an angle too.
Old 05-15-2008, 04:38 PM   #20
And I don't think those are available in the US yet.
Old 05-17-2008, 01:45 PM   #21
Car: 05 Subaru WRX STi
Fav Mod: Coilovers and X-Brace
KW's.
Old 05-22-2008, 04:38 AM   #22
Fav Mod: in transit
cobb has already for the front and rear very different design for the rear though..
impressive is offline   Reply With Quote
Old 05-22-2008, 05:19 AM   #23
Car: 08 Gray STi
Originally Posted by RallySportDirect View Post
Cusco, Tein, KW, and many other companies already have suspension out for the car. It just comes down to. What do you want your car to do?
my "plans" are cusco anti-sway bars f & r, coil overs (without a height drop since it's a dd) and some of the other cusco body stiffeners for the rear.
this will be done gradually with the coil overs not going on until the OEMs need swapping out from wear.
the problem i have right now is the patiences needed to wait for the first order (late april) to get here because the front strut was back ordered.
Old 05-22-2008, 07:41 AM   #24
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
When you guys do sway bars, make sure you do both FRONT AND REAR.
I did some testing, with just a rear sway bar. And do to the new rear suspension, the rear sway bar had results that where very different to how the car behaved compared to the previous GD chassis. It had a VERY strong tendency to oversteer at the limit. Even with the DCCD set to auto +, the back end was all over the place.
So if you do swaybars, do both front and rear at the same time.
As for coilovers. They are all designed to drop the vehicle (other then group-N rally coilovers), as a lower car has a lower center of gravity, providing better roll center to the car. So just keep that in mind when looking into coilovers.
RallySportDirect is offline   Reply With Quote
Old 05-22-2008, 09:38 AM   #25
Car: 08 Gray STi
Good to know about coil overs. Looks like they're out for me. Shocks. And springs it will be.
Old 05-22-2008, 09:49 AM   #26
Car: 2003 subaru wrx
Fav Mod: Stack steering wheel
Send a message via AIM to Ferdie
Coilovers
KW variant 3, Cusco zero 2 R, JIC
Springs
Swift are out
Sway bars,
Cobb front and rear, Progress.
We have the variant 3 in stock if anyone is interested.
Ferdie
South Coast Performance (powered by CubeCart)
7144756450
Ferdie is offline   Reply With Quote
Old 05-22-2008, 09:59 AM   #27
Car: STI's ;)
Originally Posted by Ferdie View Post
Coilovers
, Cusco zero 2 R,
Zero2-E, not R.
The R's are not available yet for the GR
There is a big difference between the 2.
Old 05-23-2008, 08:40 AM   #28
Car: Silver 08 STI
1st, tweek the tire pressures
2nd if compliance is the issue, replace bushings etc with firmer ones
3rd sway bars
etc
jrdriller is offline   Reply With Quote
Old 05-23-2008, 01:35 PM   #29
Send a message via AIM to midnit
I've got RaceComp Engineering's Sport Lowering Springs on the car right now, and will probably be rocking some Bilstein's or RCE equivalent when they are developed. As for sways, getting RCE's prototype sways in ~2 weeks or so.
Going out this weekend for some spirited driving so I can give some street feedback on their springs before they're released. Plan to do the same for the sways.
midnit is offline   Reply With Quote
Old 05-23-2008, 03:18 PM   #30
These should be out very shortly. (week or two)
CobbTuning.com - Stage 1 Suspension
parkergc8 is online now   Reply With Quote
