| | #16 | |
| Junior STI Driver Car: 08 STI Fav Mod: Driver Location: Vancouver Posts: 175
IWSTI Addict since: Jan 2008 Trader Rating: (0) | Quote:
I was told to wait until Subaru Canada find the cause and give instructions to my local service department. Please keep me updated. If the problem is 100% fixed, I might need to forward this information to Subaru Canada,so they can start to work on my car instead put me on hold forever. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #17 |
| Amateur STI Driver Car: drkgrymtalc 08WRXSTI Fav Mod: Coming Soon Posts: 16
IWSTI Addict since: Mar 2008 Trader Rating: (0) | So, I have noticed over the past 3 days of hard driving, with increasing outside air temps (high 80's and mid-90's), that if I take some good hard turns, at speed, that the sound I hear is coming from the rear of the vehicle. Brakes are not being applied during the turn, and there's nothing in the trunk to shift around. It is also not the sound of hitting the limits of traction, that is different and I've already done that. The sound is not a clunk, pop, or tapping. No lights come on in the dash either. It does sound much more like when a diesel semi-truck starts up in first gear- a deep rumbling/grinding. I have just put mile 3000 on the car, and up until 3 days ago this sound was not evident. I typically drive the car in S#, Auto-, VDC off. I looked under the car and nothing is dragging. I called dealer and going in monday to try to reproduce the sound with a tech in the car. Any thoughts? Thanx. |
| | #18 | |
| Professional STI Driver Car: Silver 08 STI Fav Mod: Coming Soon Location: Santa Cruz Mountains Posts: 490
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Quote:
FWIW, I had my car in and the verdict on my sound was that it is indeed mild brake dragging and is not abnormal for the Brembos. Repetitive clicking noises from pad movement is also apparently not unusual under certain conditions. OK by me, but I will be keeping an ear on it... | |
| | #19 |
| Junior STI Driver Car: Silver 08 STI Fav Mod: Coming Soon Location: Houston Posts: 197
IWSTI Addict since: Apr 2008 Trader Rating: (0) | guys when you say VDC off is it "off, off" as in orange indicator or just "off" as in green indicator? If it's the later then stability control is still active and will be engaging brakes depending on over/under steer sensed by the VDC controller. 1) understeer - rear inside wheel brake actuated by VDC when drift to outside detected 2) oversteer - front and rear outside wheels brakes actuated by VDC when "spin" detected This could explain some of the noises people are reporting |
| | #20 | |
| | #22 | |
| Junior STI Driver | Quote:
I know you said it does not sound like a clunk, but a grinding sound could be the same problem as this- http://www.iwsti.com/forums/2008-sti...ar-update.html Edit: Doh! I did not see that you had already replied in that thread. | |
| | #23 |
| Junior STI Driver Car: AW/Gold 08 STI stg2 Fav Mod: hands Location: Columbus, Ohio Posts: 57
IWSTI Addict since: Mar 2008 Trader Rating: (0) | any news? i have the same sound, but it gradually has gotten worse....but i work at the dealership so ill have them take a look. ill show a tech this thread, it may save some headache. |
| | #24 |
IWSTI Addict since: Dec 2007 Trader Rating: (0) | Well... my sound turned out to be brakes dragging and totally normal. However, if yours sounds more like power steering pump, I think Dante's post at then end of the first page is something you should look at. Maybe PM him for details. |
| | #25 |
| Junior STI Driver
Car: Blue '08 STi Fav Mod: Coming Soon Location: Marietta, GA Posts: 59
IWSTI Addict since: Feb 2008 Trader Rating: (0) | My noise was reduced by 90% when they installed the new p/s pump, steering gear, and had a tech do some adjustments. I'm not positive that all three are nessesary though, maybe just one or two? This ad is not endorsed by this member. Please register or login to hide this ad. |
