Old 05-12-2008, 12:34 PM   #31
Car: 08 STI
Default Re: Harman Motive 25 mm Front swaybar Installed/Tested
I run Group A and they don't have as much angle as the Whiteline pictured...I'll take some pics on the hoist this weekend.
This is the note I got when I asked Whiteline about compatibility for front endlinks and front sway...
"Hi Kris,
Thank you for your interest in our products.
We can say that the following part numbers will suit -
KCA313 - roll centre kit
KSR207 - rack mounts
Unfortunately we do not have a Sway bar or links to suit the STi as yet
and part number KCA334 - Anti-lift, we are still in the process of
confirming adaptability.
Regards
John Leighton
Technical / Customer Service
REDRANGER PTY LTD
NOLATHANE / WHITELINE / NOLTEC
Ph. 02 4340 2355
Fax. 02 4340 2466
john.leighton@redranger.com.au
Whiteline Automotive - performance handling and suspension products. car spring coil shock damper swaybar sway bar anti-sway bush bushes australia australian whiteline automotive performance road holding turn-in camber caster toe in vehicle hot 4 v8
Redranger Nolathane for longer life suspension systems
Noltec Suspension"
kris is offline   Reply With Quote
Old 05-14-2008, 06:03 PM   #32
Car: 08 STi
Thanks for posting Ploney. I appreciate the feedback, very helpful in making sure this works as planned.
RSD, etc: We designed this bar from scratch for the 08 STI. The tabs are in the same spot as stock (as you can see in that killer GIF... nice job dude). It wouldn't be any problem to increase the length of the bar by an inch, but I was concerned about contact issues w/ the endlinks when loaded.
I just wanted to confirm with Ploney - all of the pictures are with the car on the ground (loaded) right?
The first bar we made broke the stock endlinks in 1 day with street driving. They definitely are not so strong. On that bar, the angle was off by too much. I was hoping Ploney would give the new bar a shot with the stock endlinks to see if they can hold up.
Anyway, now I've got to think about whether or not to change the design a bit more. I'd definitely like this to work as well as our rear bar.
Thanks for the input everybody,
- Dan
Harman Motive is offline   Reply With Quote
Old 05-14-2008, 07:14 PM   #33
Fav Mod: Volk RE30's and 255-35 Dunlop Z1's
The car was on ramps for those pictures, weighted Dan.
I was not willing to experiment with the stock links, plus I already had the whitelines installed.
5/24 will be my first event with the DA Konis and this bar, can't wait.
Pete
ploney is offline   Reply With Quote
Old 05-15-2008, 09:29 AM   #34
Car: 08 STI
Fav Mod: Driver
Send a message via AIM to maron10 Send a message via Yahoo to maron10
Originally Posted by ploney View Post
Here is the animated gif I was attempting last night.
Shows the whiteline endlink with the stock bar and then the 25 mm solid bar.
Also, looking at your AGIF, you are not using the spacer that comes with that endlink. It appears that if you add the spacres, it would greatly reduce the angle, thus making the HM bar a viable option instead of the Perrin bar. I broke my stock endlinks on the perrin bar, so I ordered a set of the same similar spherical whiteline endlinks that you're using, and even with the spacers, the angle is still horrible. I'm going to see how well they handle this weekend at the ATL doublecross.
maron10 is offline   Reply With Quote
Old 05-15-2008, 09:41 AM   #35
Fav Mod: Wheels worth two mortgage payments
Isn't that because the Perrin STI bar doesn't exist yet and you got a WRX bar?
Old 05-15-2008, 09:48 AM   #36
Car: 08 STI
Fav Mod: Driver
I confirmed with them before and after I received the bar, they (Perrin) even had me read back the part number to them, and it was confirmed that it was for the sti.
Old 05-15-2008, 09:51 AM   #37
I have an email from them from 2 weeks ago that says
THANK YOU! PSP-SUS-115 It is not yet available, but will be will in about 3-4 weeks. If you like I can add you to the call list for when they are ready? Let me know!
Thanks for choosing ALTA & PERRIN Performance!
Is that the part number you got, or was it something else? And where did you buy it? I need one asap
Old 05-15-2008, 09:57 AM   #38
Car: 08 STI
Fav Mod: Driver
PSP SUS 121
Old 05-15-2008, 10:26 AM   #39
My whitelines did not come with fixed dimension spacers, just a but load of washers. of which I would prefer a spacer instead. Stacking up washers to me is just asking for some form of slippage/movement. I have some spacers from some other custom endlinks that I have yet to try. I am just leary of adding too much moment arm into the equation here. Thus, amplifying the chance of snapping off the tab(on the lower A arm) versus breaking the link.
Old 05-19-2008, 04:48 PM   #40
Any updates on your bars and endlinks guys? How are they holding up?
Old 05-19-2008, 08:06 PM   #41
Ya Ya...
Popped the stockers on and attended a meet and drive through some blazing 100+ temps on Sun. AC works great I can say.
I ran the bar on the stiff setting. Felt very nice, kept the front very flat, until the drivers side top link nut worked a tad loose. Had to drive home, about 60 miles, with some clunking action. That same day/night I retightened the top nut and blue loc-tited it. Today, it still worked it's way just a hair loose and is making some noise. Red loc-tite is next. Bought some, have yet to try it.....
The angle is improved with the stockers. I will be acquiring some spacers for the whitelines shortly. I had no issues when I had the whitelines on, and on the soft setting, no loc-tite either.
Pic. taken on the soft setting(Most rearward)
Old 05-19-2008, 08:09 PM   #42
That definitely looks better. I lost patience and ordered the Perrin bar the other day. I have a feeling it's the wrong one, but I'll try it and see. Maybe I'll get the Harman bar later if they would ever put it into production.
Old 05-20-2008, 09:52 AM   #43
Car: 08 STi
Thanks Ploney. I have the data I need now - I really appreciate you testing this thoroughly for us. The angle with the stockers looks way better than with the whitelines - they could def use some spacers.
We'll be putting the bar into production today. It will be about 3 weeks before I have product ready. It will be the same as Ploney's above.
I'm going to start looking into better endlink solutions too.
Thanks guys,
Dan
Old 05-20-2008, 09:54 AM   #44
Looks like I'll be using my Perrin bar for about 4 more weeks then selling it off. Awesome guys.
ps- Any thoughts on eventually producing something bigger than 25mm?
Old 05-20-2008, 10:26 AM   #45
Car: 08 STI
Ya Ya...
Stockers have less angle because they are rose jointed..take a look in your pic at the difference between the angle of the endlink bolt and a virtual straight line from the bolt head...beefy aftermarket endlinks will have a greater angle unless the aftermarket sway bar is a bit longer to make up for their lack of "flexibility" or you need to use spacers. I vote for a slightly longer sway bar.
Here are the angles on the Group A I am running:
Group A front endlinks in place on stock sway (not under load)
Endlinks under load on stock sway (would like to see aftermarket bars a bit longer as the stock bar is a bit short for non rose jointed endlinks)
