Old 05-05-2008, 01:44 PM   #1
Friendly Lurker
Car: 08 STI
Fav Mod: RCE Camber Plates
IWSTI Addict since: Mar 2008
Cool More hesitation? Wtf?
Ok. So I installed AP on Friday and it cured the slight hesitation and gave the car an obvious boost in power. Well today I noticed the hesitation again so I plugged the AP in and noticed I was only hitting 8psi ... yes I was in S#. So I pull over and check for ECU codes...there are none. I reset the ECU (cleared learned parameters) and BAM! Ok that was weird. Then it happens again. So I reset and it goes away. It is fine right now, but does anyone have a clue as to why my ecu is "learning" to reset boost to 8psi and cause hesitation problems? I mean wtf is going on?!
Old 05-05-2008, 03:50 PM   #2
Friendly Lurker
Car: 08 STI
Default Re: Stage 1 = Hesitation + 8psi? WTF?
Ok. Well I reflashed/reset. I didn't even realize how rough the car was idling I reset. Anyways, the power delivery was MUCH better. No hesitation has returned yet, no codes, just pure happiness.
Has anyone else had a similar experience?
Old 05-05-2008, 03:56 PM   #3
Car: '05 Aspen White STi
Fav Mod: Fix-it tickets!
IWSTI Addict since: Apr 2007
Default Re: Cobb Stage 1 = poop...Perrin to the rescue!
Call Cobb and let them know. If the map from Perrin fixed the issue, something is obviously wrong with the Cobb.
Old 05-05-2008, 05:26 PM   #4
Car: blue,2004,sti
Fav Mod: cobb access port
IWSTI Addict since: Apr 2008
i have the same problem but i have had the hesitation before the cobb tuning was installed.
impss is offline   Reply With Quote
