Old 05-03-2008, 04:16 PM   #1
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
Default Three datalogs of Cobb stage 1 93 octane map
Disclaimer:
I forgot to log knock correction, so these logs aren't as useful as they could be. Still, some people might like to see this stuff.
The conditions:
12C, light rain, 94% humidity, winds W 19km/h, pressure 100.71kPa, 94 octane, sea level, VDC ON, S#, AUTO-.
Notes:
The first and third logs were taken in 3rd gear while the the second log was taken in 4th.
Looking at the logs it looks like I'm hitting a maximum of 19psi in 4th and tapering off to 14psi by redline. Another thing I've noticed is that the '08 speedo seems to be much more accurate than my '05's. At 80km/h, my '05 would show a vehicle speed of 76km/h where as my '08 shows 81km/h.
I'll post up some new logs later that have KC field.
http://www.ineptitude.net:808/data/enginuitylog_20080503_162235%20(3rd-4th%20gear).html
http://www.ineptitude.net:808/data/enginuitylog_20080503_162508%20(4th%20gear).html
http://www.ineptitude.net:808/data/e...d%20gear).html
(Thanks Sleepyhead)
Old 05-03-2008, 06:52 PM   #2
Friendly Lurker
Car: 08 STI
Fav Mod: RCE Camber Plates
IWSTI Addict since: Mar 2008
Default Re: Three datalogs of Cobb stage 1 93 octane map
blah blah blah...94 oct...I am jealous of Canada!
Old 05-03-2008, 07:18 PM   #3
Car: Dark Grey 08 STI
Fav Mod: Arm rest extender
IWSTI Addict since: Apr 2008
Hey, While your at it can you log injector times? BTW, This turbo seems very capable to get more out of it, however fueling looks like it might need to be upgraded. The duty cycle is almost maxed.
I need to get some logs done on my car. Did you use the cobb ODB dongle to log. Did you need a special driver?
spongebobnopants is offline   Reply With Quote
Old 05-03-2008, 07:51 PM   #4
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
I used my old Tactrix cable (OpenPort 1.3 iirc) + latest Enginuity definitions. Drivers are included with ECUFlash.
I agree about the fueling too. At the minimum I'm going to get some Deatschwerks 650cc injectors before I go stage 2.
Old 05-03-2008, 08:18 PM   #5
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
IWSTI Addict since: Jun 2007
data is hard to read. You should post excel spreadsheets
Hitman83 is offline   Reply With Quote
Old 05-04-2008, 07:26 AM   #6
Car: OBP 08 STI
Fav Mod: AccessPort
IWSTI Addict since: Jan 2008
http://www.ineptitude.net:808/data/enginuitylog_20080503_162639%20(3rd%20gear).html
I had already done this for myself so I'll save you some work.
I guess i'm going to have to pick up the Tactrix cable because I've had no luck with the Cobb cable. Is this the correct one? tactrix
Thanks
sleepyhead is offline   Reply With Quote
Old 05-04-2008, 08:38 AM   #7
yeah, this is why the injector on times is important to me. I'm wondering if bigger injectors can be avoided with increased fuel pressure with tuning alone.
Thats is of course if the OEM injectors are rated for higher pressure.
IMO, you are probably fine with Stage 2 and these injectors for peak torque since thats a bit lower in the RPM range, but if you want to run more boost at redline something will need to be done.
Thanks for posting those logs BTW. Once I get my logging connection figure out I'll try to post some too.
Old 05-04-2008, 09:26 AM   #8
Car: DGM 08 STI
Fav Mod: cobb AP
Has anyone here modded their injectors on an 08 yet? I can't imagine it has changed too much. On 05-07 I think doing this put the injectors around ~950cc.
Old 05-04-2008, 09:48 AM   #9
Fav Mod: Me.....
IWSTI Addict since: Jun 2006
07-08 injectors are topfeed where 04-06's are sidefeed. Topfeed's are alot more common so it will be cheaper and better selection for us.
Old 05-04-2008, 08:06 PM   #10
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
Thanks for that and yes that is the right cable. You might want to wait a month or so because the maker of those cables (Colby) is working on a CAN version. With the 1.2/1.3 cable you can only datalog; you can't download the maps/ECU memory.
Thanks
Old 05-05-2008, 04:22 AM   #11
Car: 08 DGM STI
Last I checked the CAN version should be for sale on June 1st...
darrenbt is offline   Reply With Quote
Old 05-05-2008, 06:51 AM   #12
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
IWSTI Addict since: Nov 2007
its been a while since ive been to a tuning session but from what i remember its not uncommon to get the sti's injectors to 110% duty cycle.
Wales Garage is offline   Reply With Quote
