Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Tires & Wheels
Old 05-02-2008, 06:08 PM   #1
Car: DGM 08 STI
Fav Mod: Turninconcept pedals
IWSTI Addict since: Mar 2008
Default Track day wheel setup or just good tires?
I am torn if I should just get a set of summer specific tires that will work well at the track or if I should get a whole different wheel/tire setup.
Suggestions for either way? If i get the all around tire, I am ok with only getting 5 or 10k out of them.
PortlandSTI is offline   Reply With Quote
Old 05-02-2008, 06:38 PM   #2
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
Default Re: Track day wheel setup or just good tires?
well, if you're just starting on the track street tires would be good. potenza re01r's are good, falken rt-615's are cheaper and nearly as good as the potenza's. There are a couple threads on the topic so searching would probably do you well.
Old 05-04-2008, 09:09 PM   #3
Car: 08 STI and 07 R6
IWSTI Addict since: Dec 2007
I just got back from a portland trackday... the Dunlops are horrible on the track.. Maybe i'm just asking too much from the tires. they were screaming for dear life.
I'm have a ***** of a time trying to find some 17 or 18 in 9.5 inch wide rims with a proper offset to run 275 track rubber tires.
HRCboy is offline   Reply With Quote
Old 05-04-2008, 09:47 PM   #4
Car: DGM 08 STI
Yeah, the tires are not so hot. What was the track day for? What a great day for the track, I'm jealous! I am thinking about the Bridgestone RE-01R's for the summer and track. seem pretty popular.
Search for Tires by Size
Old 05-05-2008, 07:44 AM   #5
Car: 08 STI
Fav Mod: Driver
IWSTI Addict since: May 2007
Send a message via AIM to maron10 Send a message via Yahoo to maron10
I would give the dunlop Z1s a shot. I'm hearing good things about them for autocross, and they are suppose to be slightly faster and more consistent than the re-01rs. The price is also appealing.
maron10 is offline   Reply With Quote
Old 05-05-2008, 08:12 AM   #6
IWSTI Addict since: Aug 2006
Trader Rating: (14)
yep, I'm also looking at the Z1 StarSpecs, too bad the $50 rebate ended two days ago from tirerack/Dunlop.
blindfold is online now   Reply With Quote
Old 05-05-2008, 09:30 AM   #7
Car: 08 Dark Gray STI
IWSTI Addict since: Nov 2007
I have used Nitto NT01s and they work great for track days, no so good for daily drivers. I just got a set of ROTAs and Toyo RA1s. I went with 17 X 9 with a 255 RA1. 1st time out on the track with this car will be May 17 -18 at Summit Point WV. Getting white line strut tops put on today so I can adjust for more negative camber. I'm also changing the brake fluid to higher temp, SS lines and upgrading the brake pads to some PFC 01 front and rear. I'll let you know how the tires work out.
NC2008STI is offline   Reply With Quote
