Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-I.C.E/Security
Old 04-30-2008, 04:49 PM   #1
Car: 08 STI
IWSTI Addict since: Aug 2004
Default Nav - setting destinations - help
I have a problem - disk is loaded, NAV MAP of current location loads up fine, but I can't type in a destination (won't allow me to), nor can I access the NAV options setup screen. Before I make a trip to the dealer, does anyone have any suggestions.
Thanks
kris is offline   Reply With Quote
Old 05-04-2008, 11:32 AM   #2
Rum
Car: DGM 08 STI
Fav Mod: Proudly mod-free since 2008
IWSTI Addict since: Mar 2008
Default Re: Nav - setting destinations - help
ok stupid question, but - your car is stopped when you are trying to do this right?
Rum is offline   Reply With Quote
Old 05-04-2008, 08:15 PM   #3
Car: WRB 08 STi
IWSTI Addict since: Apr 2008
I had this exact same problem. I only way i found to fix it was to reinsert the Map DVD. Once you do that the nav system should reload your maps and you can enter addresses.
The symptoms i had was you press the address icon and it wouldn't do absolutely anything, and only beep. The way to tell if your maps are loaded correctly is if you have a map of North America on the left side of the destination menu.
EDIT: your car should be stopped when doing this
sparx is offline   Reply With Quote
Old 05-05-2008, 08:14 AM   #4
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
Where do you get updated maps from? Kenwood? I'm a NAV newb but I would assume you can't just throw in any GPS NAV DVD, right?
Old 05-05-2008, 08:56 AM   #5
Car: 08 sti
IWSTI Addict since: Jan 2008
Make sure the map is on ontario. My car came with the map on some state and i had the same problem. One of the menus, not sure which, sets which province you are in. I thought i was kind of stupid since i looks like you will have to change the province whenever you enter a new one.
slvrwgn is offline   Reply With Quote
