Old 09-24-2008, 12:37 PM   #211
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
Default Re: disabling hill-start assist....?
Originally Posted by Rexspeedworthy View Post
Seatbelt chime is next, anyone figure that one out?
In your manual it states that the dealership can disable this warning alarm for you. I keep meaning to have them do this but I always forget .
Old 09-24-2008, 06:40 PM   #212
Car: Black 08 STi
IWSTI Addict since: Mar 2008
The seatbelt chime is easy. Get in your car. turn the key to start (not on). As fast as you can begin to plug and unplug the seatbelt. You can just hold down the button to make this easier. You need to get about 20-25 times in and out within 30 seconds of turning the key. Then just start your car. Voila no dinging.
I swear this actually works and yes this is actually what the dealership will do. You can search for it elsewhere. You need to redo it every time you disconect the battery or reflash the ECU.
SlackerNJ is offline   Reply With Quote
Old 09-24-2008, 06:43 PM   #213
Car: Silver 08 STI(stock)
IWSTI Addict since: Dec 2005
Send a message via AIM to sutter2k
^^ Or you can pull the plug under the seat
sutter2k is offline   Reply With Quote
Old 09-24-2008, 07:42 PM   #214
Car: AW 08 STi,PSM 02 WRX
Fav Mod: More Powa!!!!
IWSTI Addict since: Sep 2008
I want to watch the person that does this
Colombo is offline   Reply With Quote
Old 09-25-2008, 12:02 AM   #215
Car: 2008 WRX STI
Fav Mod: upgrading from a WRX to an STI
IWSTI Addict since: Jul 2008
15 pages? you get used to it after awhile and then it's not noticable. stop resisting and go with it. wah
stockdiesel is offline   Reply With Quote
Old 09-25-2008, 05:31 AM   #216
Car: Silver 08 STi
Originally Posted by ScottSwan View Post
Damn, the lights... I forgot about those.
How do you kill those?
"During DRL operation only the front lights are illuminated. The DRL resistor is located under the right side head light."
Snip at the resistor?
Remember those VCR's that when you pop in a tape they automatically start playing? Yeah I used to open them up and snip the end of tape sensor wire to make that go away too!
Engineering shall not decide what I want to do...
No need to snip to disable the DRL, do a quick search and you'll see where the green plug is under the front bumper on the passenger side.
HA, I shoulda known, my 05 LGT is the same, but it never stays off. Maybe my battery is a little low, but after about 5 times starting and stopping, it "wears" off, and a clickin' I go again Seeing these cars are almost identical to the LGT in many ways, I'll got LGT.,com and find that underseat plug.
Rexspeedworthy is offline   Reply With Quote
Old 09-26-2008, 11:07 PM   #217
Car: Totalled 06 WRX TR
Scottswan, I'd recommend against that idea. Like TiC said, having the ebrake engage turns the center diff open. This could have some really bad effects everytime you push the clutch to shift.
EtoS is offline   Reply With Quote
Old 09-26-2008, 11:19 PM   #218
Car: Spark Silver 08 STi
Fav Mod: RA Mud Flaps
IWSTI Addict since: Aug 2008
uhh... this actually works and it has been documented in older posts for the earlier model imprezas.
farmboy is offline   Reply With Quote
Old 09-27-2008, 12:37 AM   #219
Car: Black 08 STi
It takes 30 seconds. And the ding is gone. Mine has been gone for months. Just had to redo it after getting the factory reflash.
Laugh if you want.
Old 09-27-2008, 12:45 AM   #220
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Has anyone tried tricking the hill assist at the actual box. Looking at the manual there is a wire that goes from the ebrake sensor to the hill assist. Just take a multi meter and measure what is going on under different conditions.
Old 09-27-2008, 07:56 AM   #221
Car: '08 WRX STI Stage 1
Fav Mod: I don't know any of the mods on this forum.
I'm a little confused about which position the key is supposed to be in for this. Is it in the ACC position where the radio works, or the ON position where the dash lights all come on but w/o the engine running?
yakkosmurf is offline   Reply With Quote
Old 09-27-2008, 10:57 AM   #222
The On position. Hold the seat belt button in so you can more easily insert and remove the seat belt latch quicker.
Old 09-27-2008, 12:24 PM   #223
Got it, worked like a charm. Thanks for the help.
Old 10-15-2008, 11:22 AM   #224
Car: 07 WRX
IWSTI Addict since: May 2007
Send a message via AIM to 96accord
I stalled today due to that damn Hill-Start Assist BS! ARGH
96accord is offline   Reply With Quote
Old 10-15-2008, 04:08 PM   #225
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
I almost did a little burnout while turning onto a street from a slight hill. Stupid hill-assist engaged while I was trying to turn left onto a fast road. The guy facing opposite me waved me to go (he was going straight) and I booted it as cars were coming. The revs came up but the car wasn't moving as fast as it should then suddenly the car shot forward as the brakes released and the rear end got a little loose. Fun stuff.
