| Junior STI Driver | I am in the decision process between the Invidia catted DP and the HM catted DP. Both are 3". The Invidia has a divorced wastegate and the cat is near the turbo. The Harmin Motive is an open bellmouth and the cat is at the end of the DP (looks just like the Cobb, but it does not have a 2.5" outlet). Any experience with cat placement? How would the distance from the turbo affect back pressure and spool up? Anything else I may need to know about catted DP's? My car is stock. I plan on using an AP along with the DP. CBE will have to wait. Thanks fellas! This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver Car: White,2008,WRX STi Fav Mod: Coming Soon Location: Denver, Colorado Posts: 68
IWSTI Addict since: Apr 2008 Trader Rating: (0) | I don't know about the back pressure and spool up but the closer to engine the hotter the air that travels through the CAT. Which if you care helps reduce emissions but it also makes the CAT wear out faster. |
| | #3 |
| Lurker | That's a good question. I'm thinking about using my Legacy GT Invidia DP and adding a cat. I was going to put the cat towards the rear of the dp so the turbo will be able to spool faster and I'll still have a divorced wastegate. Now I need to figure out if I should use a 300 or 200 cell cat. |
| | #4 | |
| Super Moderator Car: 08 DGM STI Fav Mod: My wife :) Location: Brooklin, Ontario Posts: 5,696
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Quote:
This is a bellmouth with a wastegate divider: ![]() Where as these are true divorced wastegate downpipe: Note the difference. With that said, there was a thread on this topic a while back, if I remember correctly. I'll see if I can find it. Last edited by Digitalfiend; 04-24-2008 at 06:55 PM. | |
| | #5 |
| Senior STI Driver Car: 07 OBD WRX STi Fav Mod: Coming Soon Location: Sacramento, California Posts: 354
IWSTI Addict since: Nov 2007 Trader Rating: (0) | So i know that the divorced wastegate pushes it further down the exhaust stream. But what does that do for the car? And how much of a difference would the true one make versus just the bellmouth with a flange? |
| | #7 | |
| Lurker | Quote:
And now that you mention it, I think I also remember seeing a post discussing downpipes and the different configurations. If you find it, please let us know. | |
| | #8 | |
| Lurker | Quote:
Or at least that's how I understand it. | |
| | #9 | |
| Senior STI Driver | You might be right... for the stock one. On the stock one the wastegate side is almost obstructed and this force the gases to go at a sharp angle against the gases leaving the turbo. On any aftermarket DPs that obstruction is not there leaving the wastegate gases to go almost inline with the turbo gases. The way I see it, the desired DP is the divorced one, follow by the bellmouth w divider and finally pure bellmouth. But of course each setup has his one weakness: for the divorced the wastegate tube is getting less hotter than the main DP tube => welds/tube prone to crack + high price; for the bellmouth you have the gases from both side => turbulences and small spool problems. I have the bellmouth divider That's the way I see it. Pls feel free to correct if you know otherwise. Quote:
| | #11 |
| Senior STI Driver | No offense at all, The way I see it is if you go with a divorce you can't put a big cat (APS) at the beginning and you are force to put it at the end. If you go with the bellmouth you can put where you want! Also the divorce allows more spool if you have a small cat by bypassing the wastegate gases after the cat! - see 2nd picture on this page Pro and cons on everything ! ...or go catless Last edited by cbarbu; 04-25-2008 at 12:42 PM. |
| | #12 |
| Junior STI Driver | Thanks cbarbu, I thought of catless, but I really didn't want the headache of porting the wastegate and tuning issues. Those were my 2 choices and the cat was at opposite ends of each. I was just wondering if it really impacted performance if the cat was close or far away. |
| | #13 | |
| Senior STI Driver | for the 08 I don't know, for my 07 not yet... hope so!! good luck in your choice... I'm sure if you'll do some digging you'll find a better answer! Quote:
| | #14 | |
| | #15 |
| Junior STI Driver | You are probably right given the stock turbo an IC. This ad is not endorsed by this member. Please register or login to hide this ad. |
