Old 04-18-2008, 11:29 PM   #1
Car: Black 08 WRX STI
Default Help got my first check engine light today
Hey I just got my first check engine light today!! I believe the code was 2044 or 0244 i think 2044 though. I was shifting into fifth the car spiked and lost power then regained and the check engine light came on. I pulled over checked the code with the AP then reset the ECU. Now all is good the light is gone and everything, BUT I'm a newbie to these things. I know resetting the ECU doesnt fix anything... Should I bring it to the dealer? or is i all good? My friend was telling me that these new cars are mostly computer so if it's gone and doesnt come back on its all good nothing to worry about. Please need some help
NYSTI08 is offline   Reply With Quote
Old 04-19-2008, 02:49 AM   #2
Default Re: Help got my first check engine light today
What are your modifications?
Old 04-19-2008, 05:02 AM   #3
Fav Mod: Me.....
244 code - boost solenoid failure..... get a protune or stop doing 5th gear pulls.
Old 04-19-2008, 06:23 AM   #4
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
To elaborate on what twigg said, you are seeing a boost spike or creep and hitting the built-in fuel cut safety. There are two ways to fix this. If you are only running stage 1 then you can try changing out the restrictor pill or get a Protune to have the boost spike removed (or at least minimized)
Until then, you can minimize the chance of a boost spike by not doing any 2-3K RPM pulls in 5th or 6th. Even 4th gear might give you a problem. Definitely downshift if you need to pass or accelerate hard.
By the way, are you stage 1 (tune) or stage 2 (dp + tune)?
Old 04-19-2008, 02:51 PM   #5
Fav Mod: Me.....
Sorry.... I would of explained it alittle more but I was on the pooper and had to goto work.
Old 04-19-2008, 04:38 PM   #6
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
lmao...what an age we live in...posting from the pooper.
Old 04-19-2008, 06:51 PM   #7
I just got a stage 1 tune 93 Cobb... I'm ordering a DP right now as we speak... Then I'm going stage 2...So do you think I'll be fine after this, or should i get a protune... And how much are protunes usualy and where can I get one in NYc if anyone knows?
Old 04-19-2008, 06:56 PM   #8
Fav Mod: Me.....
its time management!
Old 04-19-2008, 08:08 PM   #9
Car: 08 STI WHITE ! ! !
happened to me with the Cobb map. Switched to the Perrin map and its good
bklynpanman is offline   Reply With Quote
Old 05-13-2008, 09:01 AM   #10
wat is so different with a pro tune? wat do they do
jtrean is offline   Reply With Quote
Old 05-13-2008, 09:08 AM   #11
i eat cones
Fav Mod: catless
Sounds like a fuel cut
Old 05-13-2008, 09:32 AM   #12
Car: 08 AW WRX STI
Your tuner can correct for problem spots in the OTS map like the noted boost spike. They can also ususally improve hp/tq and power delivery without being too agressive and they can tune for specific mods that the OTS may not be able to adapt to. I'll definatley be going with a protune in the future.
GTI2STI is offline   Reply With Quote
Old 05-13-2008, 09:33 AM   #13
Car: 08 AW WRX STI
Double post. Doh!
Old 05-13-2008, 09:52 AM   #14
is it pointless to get a protune for stage 2 and a catted dp?
Old 05-13-2008, 12:35 PM   #15
Car: Blue 07 WRX STi
Fav Mod: Stage 2
I have an error in my AP it said : P0244 turbocharger wastegate soloniod "a"
range / performance its overboost problem . Easy to fix just buy a Greddy Profec B spec 2 Boost Controller ( no restriction pill ) thats what my protune did and i ran 8 times in 1/4 miles with no problem at all. No more check engine.
subaru_sti293 is offline   Reply With Quote
