Old 05-13-2008, 12:58 PM   #16
Car: 08 AW WRX STI
Default Re: Help got my first check engine light today
Originally Posted by jtrean View Post
is it pointless to get a protune for stage 2 and a catted dp?
Not IMO. I had my STG 2 catted '05 WRX protuned. Didn't see much increase in the hp/tq dept, but power delivery was much improved vs. the OTS map.
Sorry for the hijack OP.
GTI2STI is offline   Reply With Quote
Old 05-13-2008, 03:51 PM   #17
Fav Mod: Me.....
Originally Posted by subaru_sti293 View Post
I have an error in my AP it said : P0244 turbocharger wastegate soloniod "a"
range / performance its overboost problem . Easy to fix just buy a Greddy Profec B spec 2 Boost Controller ( no restriction pill ) thats what my protune did and i ran 8 times in 1/4 miles with no problem at all. No more check engine.
The stock ecu can control boost tons better for a stock turbo.
Old 05-14-2008, 11:47 AM   #18
Fav Mod: Britax Roundabout
Well, with my '08, Dan Harman of Harman Motive personally was going to pro-tune my car and came back and said he can't do much more than what the OTS map is doing for me. I have a Cobb catted DP and, of course, Stage 2 map (91 oct. Az/Ca/Nv). He said the OTS was so right on, he didn't see the point of doing a pro-tune. BUT I recently threw a code (boost) gunning it uphill on the 405 in 6th at around 3k rpm. Not sure if the pro-tune would have avoided the CEL but as long as I'm not lazy, and actually shift when I'm supposed to, the answer to your question is YES, it is pointless to get a protune with a Cobb catted DP, Stage 2 map, and otherwise stock exhaust. YMMV with other brands of catted DP but I don't think by much, if any.
Old 05-15-2008, 07:55 AM   #19
if it will make it so i dont get a stupid cel from driving my car fast then its worth it too me i really dont car ehow much it costs. $350 is worth it to me
jtrean is offline   Reply With Quote
Old 05-15-2008, 10:43 AM   #20
It's not a matter of getting a CEL while driving fast, although I don't track so going fast is usually not a good idea anyway. At any rate, looks like Cobb to the rescue with respect to the issue, v1.01 maps just released per this thread...
'08 STi - CODE P0244 - Overboost
and the Cobb site...
cobb . wrx sti accessport . map listing
Old 05-15-2008, 01:10 PM   #21
Car: 07 OBP WRX-STi
Fav Mod: Girl in the backseat
A custom tune is the best thing you can get for your car.It helps drive ability and gives a little more power that comes on smoother and better boost control.You are lucky to have an 08 so it may not be as noticeable for you but I have an 07 and it was night and day.
TuffStuff is offline   Reply With Quote
Old 05-15-2008, 03:43 PM   #22
very good news!!
